I have been planning this table for about 6 months. Naturally when I finally get the money together to buy the plate, the price of steel goes through the roof. It's only money right? I can make more.
It's a 5' x 10', 34 inches high.
I cut 6 slots on one end to use for clamping, and based it on the clamp used on the Miller ArcStation. For each slot I cut one 1-1/4" hole and one 3/4" hole, all with a bi-metal holesaws. I then used oxy-propane and a track cutter to cut the slot between the two holes, the slot is 3/4 wide.
I used 2-5/16" hitch balls for the adjustable feet. My shop floor is less than level.
I welcome all comments, and respectful critiques. Thanks!
Results 1 to 10 of 21
03-26-2011, 02:33 AM #1
- Jan 2008
- Anderson, Ca
- 31
Got my welding table done! - pics
03-26-2011, 02:33 AM #2
- Jan 2008
- Anderson, Ca
- 31
03-26-2011, 06:43 AM #3
- Feb 2007
- West Farmington, OH
- 746
It looks great! I would have never thought of using the hitch balls for leveling feet but it is a great idea. Where did you find the clamp that fits in the slots?
Now that you have it finished and start using it you'll find yourself constantly improving it such as adding provisions for storing your welding clamps, a place to put your MIG gun and so forth.
I also like that big heavy yellow thing you have in the corner, I have one as well but mine is blue!Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
03-26-2011, 07:03 AM #4
- Nov 2009
- houston pa
- 101
whats the thickness? did it distort much when you cut the slots?
03-26-2011, 01:36 PM #5
- Jan 2008
- Anderson, Ca
- 31
I wish I could take credit for the hitch balls but I saw the idea either on this forum or one of the other fab forums a long time ago.
I got the clamp from miller. They are about 40 a piece and are used on there ArcStation welding table. Now that I have one I will make my own version with different features.
I have a list of mods I will be doing over time, recieiver tubes for removable vises, mig gun holder, different clamps for the slots, storage, etc etc.
I love my old Airco. Other than the cost of adding a 100amp service just for the welder! That thing is a welding beast.Last edited by jbyrd; 03-26-2011 at 01:46 PM.
03-26-2011, 01:38 PM #6
- Jan 2008
- Anderson, Ca
- 31
03-26-2011, 01:59 PM #7
That's a great looking table. Those slots will come in handy in all sorts of ways.
My only concern would be the hitch as a self leveling foot. And the only reason for the concern is the way it concentrates the weight in such a small footprint. I'd worry that hard hammer blows might damage whatever floor surface I'm working on. But you might not do as much 'persuading' as I tend to -- I have to make up for a lot of my own mistakes.
Smart to round the corners, too.
03-26-2011, 02:24 PM #8
- Jan 2008
- Anderson, Ca
- 31
Thanks Jack, this same concern came up over on WeldingWeb as well. Maybe I can get your input on these calculations. Each ball has a flat spot with an area of 1.23 square inches. My calculations are with a the table weight 1400lbs then each leg is supporting 350 lbs. With 1.23 sq inches of the ball on each leg contacting the cement then there is 284.5 lbs per square inch on the floor.
Thoughts?
03-26-2011, 03:18 PM #9
Well, I'm no engineer. So take this with a grain of salt. But my worry would come with spike loads -- if you're hammering on the table, and the closest leg is transferring big spikes of force down to that surface area (which is what, a little bigger than a quarter?), which then transfers that force to a small section of the concrete.
I was assuming that the hitch had a sphere-like surface where it contacted the concrete. But if it's flattened, it's definitely less of an issue. And the bigger that flat area gets, the better it will work.
Then again, adjustable feet with impact-absorbing material are pretty cheap.
EDIT: Here's a set on ebay.
But again, my worry might be baseless.Last edited by Jack Olsen; 03-26-2011 at 03:21 PM.
03-26-2011, 05:21 PM #10
- Apr 2009
- KANSAS
- 511
Where did you get those miller clamps? Is that something you can order separate?
I'd like to slot mine as well.
Table looks good by the way.'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Invertec V205T-AC/DC
Miller 12VS suitcase
Miller spectrum 2050
Pipe beveler's
Track torch
