I have a welding helmet with a standard lens, i find it too dark for mig welding. Anyone has a suggestion on what lens to use for mig welding??
Results 1 to 10 of 12
Thread: another question????????
01-16-2008, 10:20 PM #1
- Jan 2008
- 4
01-17-2008, 12:57 AM #2
- Jan 2007
- Montana, USA
- 201
If you are using a #10 filter, suggest you purchase the next two lighter filters to try. Also suggest you, seriously, consider an auto-dark helmet, which has a method to vary the filter shade. Suspect that once you have used an auto-dark, you won't go back.
What is your age? Is it possible you are having near focus problems that interfere with seeing the puddle?
01-17-2008, 06:23 AM #3
Good advice above..
Can't say anymore the advice from goodhand sums it up.
TacMig.We depend On:
Burco/Koco | Onan | BobCat
We belong to or support:
American Welding Society
The Welding Institute
Anderson & Co. LLC
Metal Crafters
01-17-2008, 06:57 AM #4
better lighting in the shop can help a lot also. but getting the proper shade for the job at hand is a must. the auto hoods are great for this as its like having 8 hood's to chose from to get the right shade.
Goodhand's advice is dead on. best to have the right lens to keep you from straining your eyes they are the only set you get, invest in a good hood to protect them. i have had my BWE for almost 7 years now, so thats about $33.oo a year to see not only safely but comfortably.
P.S. i expect to get many more years use out of it as its going strong and looking great.....well time to change the battery's, but its still working great.
james@newyorkmetalart.com
01-17-2008, 08:13 PM #5
Try some different brands of filter lenses. There are different quality lenses out there and they make a big difference. You can also buy different tints, including green, more of a goldish, or even red. The difference between two different shade 10 lenses can be jaw dropping.
Just to cover the bases, is you lense and, cover lenses clean?Last edited by shorerider16; 01-17-2008 at 08:14 PM. Reason: Grammar
Dynasty 200DX, first generationMakita 5" grinder
Makita 14" abrasive sawIR SS5L compressorWhole bunch of hand/air tools.and a wish list a mile long
01-17-2008, 08:53 PM #6
- Jan 2008
- Jayton, Texas
- 12
use caution going lighter. I have a huntsman 10.5 that is not near dark enough. It will smoke your eyes welding mig with it but works great for stick.
01-17-2008, 10:48 PM #7
Going to a lighter shade won't cause any eye damage, it may just be uncomfortable. In that case you would just go back up a shade.
If for some reason you end up with a Big Window, or other Miller auto darkening lid, you can try the classic, "Should of pushed the button." trick. (You know what I'm talking about, we've all done it.
01-18-2008, 03:27 AM #8
Member
- Dec 2006
- collinsville, ok
- 86
i use a #10 gold glass. get glass and pollycarbonate clear lenses on each side of it. my shop won't let anyone use less than a 10. like fun4now said, a well lit shop helps alot.
01-18-2008, 10:27 PM #9
It depends on what you are welding too. Open corner verses tee, stainless verses mild steel covered in millscale, and so on. You may have to varry your shade depending on the application, not just the amperage.
01-19-2008, 03:19 AM #10
food for thought
An auto shade is the way to go lots of options its money well spent I have a jackson nex 3 and won,t weld wihtout it now remember you only have one set of eyes and they can,t be replaced
