Results 1 to 10 of 12
    Talking another question????????
    I have a welding helmet with a standard lens, i find it too dark for mig welding. Anyone has a suggestion on what lens to use for mig welding??
    Montana, USA
    203
    Quote Originally Posted by walterjacque View Post
    If you are using a #10 filter, suggest you purchase the next two lighter filters to try. Also suggest you, seriously, consider an auto-dark helmet, which has a method to vary the filter shade. Suspect that once you have used an auto-dark, you won't go back.
    What is your age? Is it possible you are having near focus problems that interfere with seeing the puddle?
    So. Cal
    335
    Default Good advice above..
    Can't say anymore the advice from goodhand sums it up.
    TacMig.
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
    better lighting in the shop can help a lot also. but getting the proper shade for the job at hand is a must. the auto hoods are great for this as its like having 8 hood's to chose from to get the right shade.
    Goodhand's advice is dead on. best to have the right lens to keep you from straining your eyes they are the only set you get, invest in a good hood to protect them. i have had my BWE for almost 7 years now, so thats about $33.oo a year to see not only safely but comfortably.
    P.S. i expect to get many more years use out of it as its going strong and looking great.....well time to change the battery's, but its still working great.
    Fraser Valley, BC
    593
    Try some different brands of filter lenses. There are different quality lenses out there and they make a big difference. You can also buy different tints, including green, more of a goldish, or even red. The difference between two different shade 10 lenses can be jaw dropping.
    Just to cover the bases, is you lense and, cover lenses clean?
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Jan 2008
    Jayton, Texas
    12
    use caution going lighter. I have a huntsman 10.5 that is not near dark enough. It will smoke your eyes welding mig with it but works great for stick.
    Fraser Valley, BC
    593
    Going to a lighter shade won't cause any eye damage, it may just be uncomfortable. In that case you would just go back up a shade.
    If for some reason you end up with a Big Window, or other Miller auto darkening lid, you can try the classic, "Should of pushed the button." trick. (You know what I'm talking about, we've all done it. )
    Makita 5" grinder
    IR SS5L compressor
    collinsville, ok
    86
    i use a #10 gold glass. get glass and pollycarbonate clear lenses on each side of it. my shop won't let anyone use less than a 10. like fun4now said, a well lit shop helps alot.
    Fraser Valley, BC
    593
    It depends on what you are welding too. Open corner verses tee, stainless verses mild steel covered in millscale, and so on. You may have to varry your shade depending on the application, not just the amperage.
    Makita 5" grinder
    IR SS5L compressor
    Sep 2007
    Gretna, Nebraska
    35
    Arrow food for thought
    An auto shade is the way to go lots of options its money well spent I have a jackson nex 3 and won,t weld wihtout it now remember you only have one set of eyes and they can,t be replaced
