Thread: spray arc ?
    19
    Default spray arc ?
    i went to a job interview the other day and they asked if i did spray arc welding , ive heard of it but never done it before , so they had me take a couple welding tests doing spray arc and it was super easy and kinda fun ,, so what im wonder is can i spray arc with my mm252 ? and how would i need to set it ?
    Chico, Ca.
    316
    your 252 will spray. you need at least 85/15 gas preferably 90/10. depending on the metal thickness you have to crank your volts and wire speed up.
    miller 225 bobcat
    miller aead200le (with miller hf tig trailer mounted)
    mm175, mm211, TA181i
    mm252 w/30a spool gun
    precision tig 225
    hobart stickmate LX ac/dc
    Speedglas 9100X & XX / Miller Digital Elite
    hypertherm 380 & cutmaster 52
    victor journeyman & super range
    ridgid chop saw, kalamazoo band saw
    steel max and evolution carbide saws
    6 4.5" & a 20lb 9" rockwell grinders
    case 580 backhoe (for what i can"t lift)
    if first you don't succeed
    trash the b#####d
    Deltaville, VA
    2,239
    Got to the top of the page and click on the Resources tab.
    Look for Miller's offer for their "Student Pack".
    It's $25 including shipping. Order it. Best $25 you'll ever spend on welding.
    Has an excellent Tig Handbook, a GMAW Handbok, a GMAW-P Handbook, and a bunch of other useful goodies (like welding calculators).
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    May 2010
    Central CA
    785
    Default Calculators
    The Calculators that SundownIII refers to have spray arc settings.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Mar 2011
    Theres 3 different modes of transfer with Mig. Short circuit, globular and spray. Basically what's happening with Spray is the wire is melting before it contacts the plate and "sprays" onto the metal and wets in. In a normal short circuit setting, the one your used to, the wire actually contacts the plate, shorts out and melts into the plate. Spray needs a more Argon rich shielding gas to function. This is also done at much higher heat settings with thicker material.
