Results 1 to 2 of 2
    Dec 2009
    Riverside, Rhode Island
    9
    Default Bucket pin clearance
    i am in the process of machining four steel bosses to be welded to a used but in very good condition excavator bucket.The pin size is 2.50 inches in diameter and each pin (two) will rotate in two of the new bosses "with grease". What should be the final running clearance ? I expect to bore ,weld ,then line ream. Thanks for any help. MrH
    Jan 2009
    Whitehorse, Yukon
    279
    Typically you're shooting for 2-3 thou per inch clearance, so you would be lookin at 6-10 thou. On a 2.5" pin I would machine to 2.450" then do the install. Afterwards, line bore to a finished diameter of 2.508" to 2.512" or so.
    Big Blue 400D
    Trailblazer 302
    Miller S-32 suitcase
    12VS suitcase
    Lincoln LN-7 (BIG suitcase)
    Victor torches
    Lincoln 350MP with 35' push-pull gun
    Lincoln PrecisionTIG 375
    Spectrum 1000 plasma cutter
