Results 1 to 2 of 2
    Jan 2007
    2
    Default 12 kw gwnerator 120 / 220 single phase for tig
    i have a 12kw trailer mounted generator 120 / 220 single phase
    can i run a miller dynasty 200 dx from this or similar unit
    are there other ac tig machines that will run off a generator
    what are limitations for gen and welder
    thank you
    tom
    Jan 2008
    Northern California
    20
    Default Generator
    According to the spec sheet from Miller, 4.7kw is all you would need on single phase to run the 200 DX. As far as limitations, I don't know of any.
