Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
  1. #31
    Oct 2009
    Richmond Va
    57
    Quote Originally Posted by Markswelding View Post
    I'll try posting here but for the wise please keep your stupid comments to yourself.
    1) need at least 80' good string
    2) a good surface
    3) at minimum a set of "strong backs" to keep it straight while welding
    4) a good welder, as in machine as well as a weldor
    5) air arc for back gouge, or at least a nicely made prep joint, bevel 30deg. On flanges (4)
    6) I would use 3 plates to "fish plate it", top 2 sides of web.
    7) after fish plating, if you really want safety you could bolt, 5/8 - 3/4 structural bolts in a few figured in places would be a security measure.
    Good luck in your endeavors, be work safe, but frankly & I forget size of beam but I can look for specs in Bethlehem steel book at home.
    For a 1000lbs I think it sounds like overkill as to beam size, hopefully not rusted.
    Check the deflection in 1 beam proped up on bothe ends check sag, you can do this on ground before trying to get into the air.
    Hope this helps, if you were close I'd offer a weld job for you if yours is questionable. But don't settle for a back yard weld.
    As for when things fall there's no stopping that kind of weight.
    Remember to if you should "jerk it" a 1000 lb load could easily double in weight.
    Have a great safe project
    Thanks my friend, it sounds like I am on the right track. Let me ask you one thing for clarity, when you said use three fish plates, one on top and bottom and one on the web; would you solid weld all the edges? I had planed on sandwiching the web with 2, 1/2" pieces of plate 24" long and 6" wide one on each side. I have already drilled the plates for 5/8 " bolts and I planed on putting two lines of bolts of 4 each in a staggered pattern on each side of the weld or 16 bolts per joint.
    I had also thought of making two splices in the beam one at 10 ft on each end. My thinking was that this would place the welded points in places of less stress. Do you feel I need to go this route if I plate the beam as I described? I welded two pieces of beam together today that I plan on using as a brace for another project and I had almost 3/4 of a day by the time I was done. This was a practice run to see how straight I could make it and it turned out pretty nice if I say so myself.
    I don't have an air arc setup so I had to grind the joints and I don't know about the 30 degree thing I'm not as steady as I used to be but it didn't turn out bad. Also what rod would you think is best suited to get the best all around results. I'm not a welder by trade but I have welded plenty over my life time and where as sometimes it ain't pretty like I have seen others do I haven't had a weld break yet. I have a 295 Amp buzz box I do most of my stick welding with but I could use the Dynasty 350 if I had to it's just that it would be a pain to get it out to where I have to weld this long section. I could also mig weld it but it would be harder to get that machine out there than it would be the blue one. Thank you
  2. #32
    Oct 2009
    Richmond Va
    57
    Well today I had a helper and I dragged the beams up to the garage where I could start work on them. I decided to go with the two splice deal that I had originally thought about and everything went well after we figured out how to lay them out where we could work on them. We got both joints almost finished before it got too dark outside and all that is left is to do a little finish work. I still need to weld my top and bottom fish plate and I still need to drill my holes in the web to match the holes in the 4, 1/2" plates I plan on using where the web is welded. Another day and I can drag the whole mess down the the building pad where it will hopefully live one day. If all goes well I'm hoping to get my post and headers in this week and maybe even get the beam hoisted up and bolted in place.
    I have a lot of cutting, welding and grinding to go yet but once it's up I'll take a pic of this beast and try to post it to the board. That is if it don't break in half like some people seem to think it will.LOL
  3. #33
    Apr 2006
    TAXACHUSSETTS
    1,503
    All i can do is laugh.If you need to ask what rod to use to do this you need to hire a professional.No disrespect but come on????
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
  4. #34
    Oct 2009
    Richmond Va
    57
    Quote Originally Posted by admweld View Post
    Well while you are laughing and not disrespecting an all...... Maybe you would like to at the very least while all this is going on, throw out an opinion as to what a big professional like yourself would use to weld the beams together.
  5. #35
    Deltaville, VA
    2,239
    It wouldn't matter what a "professional" recommends. You're going to use whatever you already decided to use.
    Not only do you seem to be one of those guys who subscribe to the "don't confuse me with facts, my mind's made up", but you also seem to have difficulty with "reading comprehension".
    Not only do you totally reject advice from guys who know the business, but then along comes a poster "who gives you advice you wanted to hear". Never mind that it was the worst advice tendered to date, it was sorta what you wanted to hear. You thought it was great, except that you "read into" his post what you had already decided, rather than what he'd posted.
    That poster stated, "I would use 3 plates to "fish plate it", top 2 sides of web." In other words, he would leave the bottom flange unreinforced. Yeah, that's great advice, especially since the bottom flange will be carrying the tension load in this beam.
    This entire post has been an exercise in "how not to" approach a project. Here's a couple examples:
    First we never learned (nor did you) exactly what beam we're dealing with. Just that it's a W10. Could be a 19, could be a 21, whatever. Little things like that are important.
    Since we never knew what beam is being used, no one could say with any certainty what load carrying capacity it would have, even without a splice/splices.
    When bolt splicing an I beam, the bolt pattern is "designed" to distribute the load, not where the bolt holes "look good". Same thing with fish plates. Size, shape, and how they're welded are critical to achieving maximum strength.
    When hanging a structural steel beam, you don't "think" it's good enough and I'll add additional support "if needed". You know what you're dealing with going in.
    Most "welders" know that 7018 is a DC rod. But, I guess that's one of the points that shipyard welder forgot to tell you when he was asleep and you were burning away.
    Small point, but it shows the "attention to detail" that we're dealing with here. Miller did not make a Dynasty 350 5 or 6 years ago as you state. I suspect the machine you have is a Dynasty 300. Not that it matters, but I've found that people that are sloppy (non detail oriented) in one area, that the same traits tend to carry over into other areas as well.
    Whatever rod you decide to use, you may want to consider dipping them in ****** before welding. I think that beam is going to need all the "stiffneing" it can get.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
  6. #36
    Deltaville, VA
    2,239
    Dang "word police"
    Substitute in V I A G R A .
    Dynasty 200 DX
    Hobart HH187
    Dialarc 250 AC/DC
  7. #37
    Oct 2009
    Richmond Va
    57
    Dang "word police"
    All I have heard out of you is a bunch of petty jabs and a snarl or two here and there. You remind me of an old over the hill woman that just isn't happy about anything and is always looking for something to bit*h and gripe about. Rather that waste your time here why don't you either post something of substance or just go in the back room and take a toke off the bong or another hit out of the metamucil jug. If you know all this stuff post it up and help out.....if not, please kindly just go your own way and leave me the heck alone.
  8. #38
    WY...armpit of U.S.A.
    659
    Quote Originally Posted by mx842 View Post
    Wish I had SundownIII within 75-85 miles. I can't say what many would do, but I'd be leery about posting any advice to anyone that doesn't want to spend the time to do the job right. If you don't want to be bothered by members of the board carping on your inability to understand what is involved, put them on 'ignore' and their comments and criticism will disappear. Do it at your own risk.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
  9. #39
    Apr 2006
    TAXACHUSSETTS
    1,503
    7018 1/8.Also being the professional i am i would not even take a job like this with out a structural engineers stamp on a set of drawings with a WPS included.I can,t tell you how many times i have had to explain this to customers.That i am a welder,not a engineer and have no business in sizing steel for a job.But then again i have liabilty insurance and alot to lose so i must be an idiot.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
  10. #40
    Dec 2010
    East Coast of US HellTown Pa
    20
    Default I'm just doubly bubbled dumb founded
    Sundowner; I tried to send a message, your box is full empty it?
    MX842, yes as in what others have said, I as well said, but maybe not clearly enough. (and as well the bottom flange should be plated).
    You probably should have some "professional type" help for your job.
    I myself know what I can get away with but then I've been a welder for 30 yrs, fit & fixed lots of stuff, so I have a pretty fairly good idea of what I can get away with.
    If you do this you can't just shmuck it together, for those of us that weld a lot it would be easy, but your questions do leave me with worry.
    What size are the flanges?
    Good luck but don't hold me to any responsibility get qualified help.
    Mark
Tags for this Thread
