Results 11 to 12 of 12
    Dec 2011
    418
    Just a thought,
    Check for loose/displaced pins/sleeves in the connector(s) or cracks in the circuit board traces -might occur close to the connector mounting. Use a good big magnifier. Doesn't seem to be a common cause but you never know..
    Meltedmetal
    Or maybe try some freeze spray to isolate ? Also cold solder joints?
    Jan 2013
    Pins and connectors seem OK, but hard to tell on the female parts (ain't it always the way?).
    Looks like I'll have to pull the circuit board out and check for loose connections. Anything tricky about that, does anybody know?
    --Buckapound
