I was given a Miller Cricket from my brother in excellent condition. The problem I am having is buying a spool of wire for it. The Cricket has a large diameter hub but all 1 - 2lb spools in the stores fit a small diameter hub. There seems to be no option on the Cricket to change to a smaller diameter. The only spools that will fit are the large spools and I don't do enough welding to justify a spool that size.
Does enyone have any ideas or has run into this problem?
Thanks for any advice you can give.
01-14-2008, 07:21 AM #1
- Jan 2008
- Noblesville, Indiana
- 2
Need help with old Miller Cricket
01-14-2008, 07:33 AM #2
Have you considered buying a 8" roll of wire on flea bay?
You can buy a single 8" roll of .030 mig wire for around $22 to 25.00 shipped to your house. I doubt you'll be saving much money by buying the smaller 1-2 lb rolls. Just make sure you take the wire out and store it inside the house to keep it from rusting if you're not going to be using for a long time.
http://cgi.ebay.com/ER70S-6-Mild-Ste...QQcmdZViewItem
http://cgi.ebay.com/Weldmark-70S-6-C...QQcmdZViewItem
2 Roll of wire for around $32 delivered. You can buy this with a friend get a roll for $16.00 delivered.
http://cgi.ebay.com/2-10-lb-Rolls-ER...QQcmdZViewItemMillermatic Passport Plus
Millermatic 350P with Python
XMT 304 /w S-64 feeder and 12VS
Dynasty 300 DX
Thermal Arc 400 MST
Premier Power Welder for my trail junk.
01-14-2008, 08:37 AM #3
- Jan 2008
- 2
I guess that's not too bad an idea. Pound for pound the 8" is probably cheaper in the long run.
Thanks for the tip.
01-14-2008, 10:00 AM #4
You're welcome... BTW, welcome to the site...
Dynasty 300 DX
Thermal Arc 400 MST
01-14-2008, 10:29 AM #5
it is cheaper to get the larger spool. i was thinking you could get an old 8" spool and rewind but that would not work out so well, liable to bind up a lot.
first time i got a 8" spool for my MM135 i fell in love, hate changing role's
. now its always got wire when i need it.
if it sits too long and gets a little surface rust i just run off about 20ft and its good to go again.
james@newyorkmetalart.com
