Results 1 to 5 of 5
    Feb 2011
    DFW, TX
    24
    Default fireplace screen question
    I need to build a couple of fireplace screens. Need a recommendation for woven wire screen material. Wire dia? square opening? woven vs weld wire? Hard to tell from Mcnichols webpage exactly how big the openings and wire is.
    Thanks,
    Rocko
    Salem ,Ohio
    3,954
    Cool
    I wouldn't go any bigger than 1/4" sq. I made them for 10 years in my dads woodburner factory. I remember ours being about 3/16" sq. Heres a tip to attach the screen to a frame if you use it. Take a small washer and plug weld the washer thru the screen welding it to the frame. It will take more abuse and not pop off as easy as just tacking the screen...Bob
    Default Firescreen
    Expanded mesh works well for firescreens, looks even better if its rolled as well.
    Welding is so much more than a hobby. It is a fun way to earn a living working from home.
    http://www.weldathome.co.za
    Feb 2011
    DFW, TX
    24
    Thanks for tip! Gonna try it!
    Nov 2007
    Central Idaho
    205
    Be careful about code compliance. Call McNichols direct, tell them the application, and they will recommend the proper material.
