Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    Jan 2007
    105
    Default railroad track weldability?
    I saw a de-railed CN train today downtown and the tracks where mangled .. i was thinking are railroad tracks tougher steel? and weldable?
    i was thinking i could use them on a Cat bulldoser ripper project if there stronger. The catapiller brand and Accurate brand ripper teeth wear out too fast and cost to much for what the customer is doing.
    Jorgensen MFG.
    Custom trailers:from utility to semi trailers i make em all.
    argonweld_bjorn@hotmail.com
    www.ehhitch.com
    Jun 2006
    Calgary, Alberta
    377
    I suppose it would depend on the type of ripper /CAT product. RR track used for a ripper shank on say a 140 grader might work, but welding a chunk to the cutting edge of a D10 ripper shank probably wont. Rail is a higher carbon steel and hardened, to what specs I don't know, but I believe it is harder and tougher than any CAT ground engaging implement. I work for CAT, and the repair procedures for ripper shanks doesn't seem to work for welding rail.
    If anyone has any input into the mechanical properties breakdown of rail, please post.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    Jan 2007
    105
    i just want to weld a couple flat bars on the side for a stop when sliding into the recerver part of the ripper, i'm going to cut the rail on a 45* and put it in i'm thinking.
    Jorgensen MFG.
    www.ehhitch.com
    Mar 2007
    ****inson ND
    557
    Talking
    RR tracks are usealy welded using the thermite method. Very large castings are also welded in place using this method as are under water structures
    Oct 2006
    British Columbia
    500
    Cool Rail road castings
    Hey Bmxin^Bjorn there is a place in coquitlam calles nortracks they weld that stuff I worked for them for a while very dirty work anyway to weld this stuff you need magnesium rod it burns just like 7018 they have a contract with essco in coquitlam also. I never did try to weld ms to this stuff hope this helps.
    Mar 2006
    Ocean City, Maryland
    951
    Smile
    Quote Originally Posted by Anti-GMAW View Post
    Dumb question maybe, but what is the thermite method? In the Marines we had thermit grenades ha ha ha
    Scott
    HMW [Heavy Metal welding]
    Dec 2006
    Alaska
    732
    Quote Originally Posted by HMW View Post
    Same thing just not constricted so no boom.
    I think thermite is a combo of aluminum and steel oxides and once you light them off they will burn very hot for as long as the fuel is present. I think they add some powered steel to the mix and that acts like a filler. For RR track they have a form they place and clamp around the track fill it full of the thermite and add a spark and you got a weld.
    Electricians use this method for bonding ground straps.
    TJ
    TJ______________________________________
    Mar 2007
    356
    if its just basic stops, 7018 and away you go
    mm210
    maxstar 150
    Jan 2007
    Noth Dakota
    505
    Cool
    I would get a new tooth and hard surface the front and sides full coverage twice with Stoody 101HC. If that didn't last long enough I would call Stoody for their recommendation for the job at hand. I would want a high abrasion hard surface for a ripper tooth. Maybe a different style tooth is needed as they make all kinds for different conditions.
    Mar 2007
    ****inson ND
    557
    Talking
    Try this link. http://en.wikipedia.org/wiki/Thermite
    I'm a bit of a pyro and also a self proclaimed explosives expert. I pride my self on being able to tell ppl the exact chemical make up of certian reactive substinces and there common practical uses. Don't go quizzing me on explosives though cause I'm extremly cautious (spelling?) and parranoid about who I give that info out to. My answers are usualy thourough enough to get certain ppl into trouble. If you wish to know more about thermite however I'd be glad to share my knowledge with you. I "play" with the stuff quite often and love to burn through junk with it. It's completly legal since it does not produce an explosive reaction. Ican also provide info on where to get the material at a prety reasonable cost. I tend to use such large quantitys screwing around with it that somtimes I have to go the budget route
