    Jul 2010
    central Kansas
    66
    Default Back hoe pivot job
    Job from today.
    Wasn't to bad 1/4" in play on 2-3/16 pin
    First we heated and bent the ears back in line rosebud and 60 ton portapower to pull it together
    weld bore up
    1/8 7018 110 amps
    pics after straitening ears
    weld bore up
    install cones for rough position
    Jul 2010
    central Kansas
    66
    Default continue
    set up feeder
    rough bore
    Finish bore
    KANSAS
    511
    Pretty boring stuff
    Glad to see your still kickin'. How far was the ears bent out?
    '08 F-350
    Vantage 400
    SA-250
    SA-200
    Invertec V350Pro
    Invertec V205T-AC/DC
    Miller 12VS suitcase
    Miller spectrum 2050
    Pipe beveler's
    Track torch
    1,910
    Nice job. Since I don't have access to this type of equipment I would of had new bosses machined, cut out the old & welded in the new. Just curious, can you post a pic of the actual cutter? Is it a single bit like on a lathe or multiple cutters like on a ream? I've only seen a larger version & that had a single cutter. They were doing about a 10" dia. bore.
    Jul 2010
    central Kansas
    66
    Quote Originally Posted by Rig Hand View Post
    Pretty boring stuff
    Not to bad 3/4 inch.
    So are u back in the flat lands if so come on down ill buy lunch.
    Jul 2010
    central Kansas
    66
    We considered that but by the time we machined new bosses cut them out and welded them in it costs more than just building them up. And I am not a good enough of a welder to weld in the new bosses and keep finished bosses strait enough. so would need line boring any how.
    I use single point brazed carbide tools just like on a lathe.
