Results 1 to 8 of 8
    Default would this work?
    I want to build a bumper for my ATV using 1/1/2 round tubing, i seen a pipe bender for sale for 50 bucks but im not sure if it will bend what im wanting to bend,
    http://www.princessauto.com/workshop...ic-pipe-bender
    thats a link to basically the same thing i can get for 50 bucks, but im kind of new to this and unsure if the metal to build a atv bumper would be bendable with this machine....
    any info would be greatly appricated.
    Chico, Ca.
    315
    it will work but not to perfection as the diameters of the pipe and tubing are different. the tubing being narrower will tend to get distorted in the bends. imagine looking at the egg from it's side laid flat. i have the hf bender which looks the same as the one in the link and that is what happened when i bent some tubing. i haven't tried it but i have heard that if you take some thin sheet metal and form it to fit the die it will stop the egg shaping.....jim
    one more thing to consider is that it will be hard to get small radius bends with this bender, which i think you will be trying to get on a atv guard. you might cap the tube with a plug and fill with sand and and use heat to bend the tight bends. that has worked for me.
    miller 225 bobcat
    miller aead200le (with miller hf tig trailer mounted)
    mm175, mm211, TA181i
    mm252 w/30a spool gun
    precision tig 225
    hobart stickmate LX ac/dc
    Speedglas 9100X & XX / Miller Digital Elite
    hypertherm 380 & cutmaster 52
    victor journeyman & super range
    ridgid chop saw, kalamazoo band saw
    steel max and evolution carbide saws
    6 4.5" & a 20lb 9" rockwell grinders
    case 580 backhoe (for what i can"t lift)
    if first you don't succeed
    trash the b#####d
    so it will be more of a pain in the ass by the sounds of it, I was kind of figuring that. all well its only 50 bucks, i guess ill buy it doesnt hurt to have more tools.
    thanks for the info
    Chico, Ca.
    315
    Quote Originally Posted by hit_em View Post
    thanks for the info
    spoken like a true toolaholic. don't forget to "not" tell the wife.
    miller 225 bobcat
    precision tig 225
    trash the b#####d
    Cleveland, Ohio
    38
    If you want to use that bender why not make the bumper out of 3/4 or 1" pipe?
    I have read (it's on the 'net so it must be true ) of people bending pipe in the bender then cutting it lengthwise to line the die to make it the right size. Since 1.5" pipe is 1.5" on inside, whereas 1.5" tubing is 1.5 on outside, it seems as it could work but I've never done it myself.
    Chico, Ca.
    315
    Quote Originally Posted by tenfingers View Post
    i was thinking the same thing. just use pipe of appropriate outside dimensions but the problem would still be trying to make the tight bends associated with such a small bumper. unless that bender comes with smaller radius dies than the hf bender. but then on the bigger bends he could use the bender and other means on the tight ones.
    miller 225 bobcat
    precision tig 225
    trash the b#####d
    2,634
    Don't design tight radius bends in yer bumper
    http://www.atventure-accessories.com...erProducts.php
    Just an example
    get crazy
    http://www.google.com/images?hl=en&s...ql=&oq=atv+bum
    Chico, Ca.
    315
    Just an example
    get crazy
    heck Ed, those would look good on my Polaris
    miller 225 bobcat
    precision tig 225
    trash the b#####d
