Results 1 to 10 of 15
Hybrid View
    Question Welding table wheel questions
    I am going to build the Miller design welding table:
    http://www.millerwelds.com/interests...welding-table/
    The plans call for two swivel base wheels (locking) and two stationary wheels. I will be moving this table around on the concrete floor of my shop. Is there a reason not to use swivel base wheels for all four corners instead of using 2 swivel wheels and 2 stationary wheels? Wouldn't it be easier to turn and move the table around if all four wheels were locking swivel wheels?
    I read the other threads on the forum about welding tables. A few people mentioned having a threaded leg mount to one of the wheels so that you can level the table. Would you only need to do this to one corner? Can anyone post a photo showing how to set up the threaded adjustable leg?
    Thanks!
    Apr 2010
    Jackson, MS
    79
    Four straight wheels go straight but don't turn. Four swivel wheels turn easy but hard to keep going straight. Two swivel two straight goes straight and is still pretty maneuverable. If ever decide to change the orientation of your table, then you are going to need your levelers on each corner.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Spectrum 625 X-Treme
    Dayton 6" Miter Band Saw
    Delta Drill Press
    Bosch 10" Table Saw
    Bosch 12" Double Bevel Miter Saw
    Jet 5 Ton Chain Hoist
    Radnor O/A
    and this heavy duty table I made
    Sep 2007
    Medford MA
    542
    i used to do 2 straight +2 swivel
    i've changed over to 4 swivel
    it's just a lot easier maneuvering stuff
    around in my small home workshop
    if you want to movemsomething straight,
    pull it, don't push it
    if you wish to level the table then you need
    levellors on all 4 legs. what happens if you lift
    one leg of a chair off of the floor?
    frank
    Question Leveler details/photos?
    FJK, I think I will also go with four swivel wheels because I will be moving the table often, and like you said, I can pull the table to make it go straight.
    I have no idea how to build the levelers on the legs. If someone would post photos of that setup, I would appreciate it!
    Thanks for your replies!
    Los Angeles
    2,908
    I built my table off of those same plans and just recently changed out the fixed wheels.
    I do not have any levelers, floor is pretty flat.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Sep 2006
    Abilene, Texas
    639
    I built my tables with 4 swivel/locking casters. They work okay, but I wanted the maneuverability for a small area. If you have a pretty good size floor, I'd opt for 2 swivel and 2 fixed. They will allow you much better control, but not quite as much maneuverability in a close space. The problem with 4 swivels is that they all seem to have a mind of their own. lol
    Jim
    Sep 2007
    Medford MA
    542
    Quote Originally Posted by OregonWelder View Post
    Most that I've seen (sorry, don't know of any photos off the top of my pointy head)
    use a combination of a levelling mount (go to www.mcmaster.com and search
    for levelling mount) and caster. The caster is attached to the side of the leg, while
    the levelling mount is directly under the leg and screws into it.
    Frank
    Nov 2009
    Regina Sask. Canada
    15
    Default leveler
    Built a table a while ago, search for post, the outside orientation lets me use the table weight to clamp down my 12 inch shear for temporary jobs. Fred
