Results 1 to 10 of 15
    Question Welding table wheel questions
    I am going to build the Miller design welding table:
    http://www.millerwelds.com/interests...welding-table/
    The plans call for two swivel base wheels (locking) and two stationary wheels. I will be moving this table around on the concrete floor of my shop. Is there a reason not to use swivel base wheels for all four corners instead of using 2 swivel wheels and 2 stationary wheels? Wouldn't it be easier to turn and move the table around if all four wheels were locking swivel wheels?
    I read the other threads on the forum about welding tables. A few people mentioned having a threaded leg mount to one of the wheels so that you can level the table. Would you only need to do this to one corner? Can anyone post a photo showing how to set up the threaded adjustable leg?
    Thanks!
    Apr 2010
    Jackson, MS
    74
    Four straight wheels go straight but don't turn. Four swivel wheels turn easy but hard to keep going straight. Two swivel two straight goes straight and is still pretty maneuverable. If ever decide to change the orientation of your table, then you are going to need your levelers on each corner.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Spectrum 625 X-Treme
    Dayton 6" Miter Band Saw
    Delta Drill Press
    Bosch 10" Table Saw
    Jet 5 Ton Chain Hoist
    Radnor O/A
    Sep 2007
    Medford MA
    524
    i used to do 2 straight +2 swivel
    i've changed over to 4 swivel
    it's just a lot easier maneuvering stuff
    around in my small home workshop
    if you want to movemsomething straight,
    pull it, don't push it
    if you wish to level the table then you need
    levellors on all 4 legs. what happens if you lift
    one leg of a chair off of the floor?
    frank
    Question Leveler details/photos?
    FJK, I think I will also go with four swivel wheels because I will be moving the table often, and like you said, I can pull the table to make it go straight.
    I have no idea how to build the levelers on the legs. If someone would post photos of that setup, I would appreciate it!
    Thanks for your replies!
    2,636
    I built my table off of those same plans and just recently changed out the fixed wheels.
    I do not have any levelers, floor is pretty flat.
    Sep 2006
    Abilene, Texas
    639
    I built my tables with 4 swivel/locking casters. They work okay, but I wanted the maneuverability for a small area. If you have a pretty good size floor, I'd opt for 2 swivel and 2 fixed. They will allow you much better control, but not quite as much maneuverability in a close space. The problem with 4 swivels is that they all seem to have a mind of their own. lol
    Jim
    May 2006
    176
    On my 4'x8'x1/2" table with six legs, I used four swivel casters on the corners and two screw-down supports on the center legs. I can support most of the table's weight when working at the table using the supports and raise them to wheel the table around. The table weighs nearly 700lbs. so it takes some effort to move it. I felt this method offered the best compromise for portability vs steadyness and support.
    The two screw down supports are 7/8" machine thread stock I found in a scrap yard and I bought matching nuts for the end of the legs. I boxed the nuts using a "U" shaped piece of 14 ga steel with a hole cut to 15/16" using plasma. I thought this a better choice than welding the nuts to the ends of the legs. I made and attached a swivel pad to each of the ends of the supports. I cross drilled each support for a sliding 1/4" x6" handle for leverage in raising and lowering the supports. If you search for old threads, I think you can find photos previously posted.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    Jul 2008
    Delhi, Ontario:
    1,950
    dmaxer, Just the 4'x 8' x 1/2" plate = 653.5 Lbs. , you must have had fun mounting that baby !
    ....... Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    Apr 2010
    Jackson, MS
    74
    This is how I mounted my 3/8" top. Not quite 653.5 lbs, but 500+ still hurts the back.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Delta Drill Press
    Bosch 10" Table Saw
    Radnor O/A
    Sep 2007
    Medford MA
    524
    Quote Originally Posted by OregonWelder View Post
    Most that I've seen (sorry, don't know of any photos off the top of my pointy head)
    use a combination of a levelling mount (go to www.mcmaster.com and search
    for levelling mount) and caster. The caster is attached to the side of the leg, while
    the levelling mount is directly under the leg and screws into it.
    Frank
