Results 11 to 14 of 14
    There is a way to weld it to prevent the panel from bowing.
    The welds now are holding the pickets with a vertical weld on each side of the picket. So when you add up all of those transverse welds on the frame the pickets are attached to, the amount of shrinking of each weld is what is making the frame bowed because they are all on one side of the tubing . When all are added up.
    Instead of welding vertically on each side of the picket to the panel rail weld the
    pickets on the horizontal on the bottom of that top rail and on the TOP of the bottom rail.
    That way all of the welds will be longitudinal on that panel rail and on the very corner. I will post a drawing.
    The other thing you could do is to put the pickets on alternating sides and then there would be an equal number of welds on both sides of the rail the pickets are attached to. Shrinkage would be equal on both sides.
    One more possible solution.
    Visualize this in steel.
    Put a rail on both sides then there will be equal welds on each side and the welds will be less visible.
    And one more idea...
    If you took the bowed panel and lay it on the ground and pass a torch flame down the opposite side of the panel the same direction as the weld ,every where there is a weld, then the panel will shrink on that side and it will flatten out.
    You could start in the middle and work your way towards the ends. Just do every other weld to start with and maybe that is all it will take. Just a red hot path going the same direction of the weld but on the opposite side of the tube.
    alabama
    754
    Quote Originally Posted by Donald Branscom View Post
    Sir,no disrespect but regradless of how you weld those pickets, as long as they are welded on one side it will bow.Fabricate a 6 foot section welded like you say and post a picture. I personally run my horizontal pieces thru my roll bender first to put a slight bend in it before I weld the pickets on but everybody has their own method.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Mar 2009
    234
    Thanks for documenting this so well. You might hate ornamental fencing, but the rest of us like seeing a project like this done by a man and not a machine.
    When I made the fence for my yard, I came up with a system to 'unbend' each section on the table that had held my jig. It would take a few minutes for each section -- a variation on the 'jump on it' technique you described in your posts.
