Results 1 to 7 of 7
    Nov 2012
    1
    Default MillerMatic 200 + SpoolMate 100
    Have use this gun frequently, with a 211...but never with steel wire (NOT flux-core), always with aluminum.
    Will this gun run steel wire with the 200?
    And can I use ARGON...instead of CO2, since I have Argon in abundance?
    Oct 2004
    Edmonton, Alberta
    8,325
    Steel works fine with any spoolgun, though if your a welder, you should know better on the Argon issue
    Jul 2008
    Delhi, Ontario:
    1,998
    Quote Originally Posted by buzz254 View Post
    I assume you mean Argon Mix ( 75-25 ) Not straight Argon !
    Pure Argon is for welding aluminum !
    ...........Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Salem ,Ohio
    3,954
    Cool
    I think the bigger question is how are you going to run the Spoolmate 100 on a MM200. Just my thoughts...Bob
    Aug 2008
    Orange, TX
    1,217
    About the only way would be coupled to an SGA 100 with a modified control cable plug to fit the MM200 4 or 14-pin spoolgun control receptacle depending on its generation.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Mar 2013
    1
    Default will the spoolmate 100 direct conect to my millermatic 200 serial number JF946510
    Quote Originally Posted by aametalmaster View Post
    my millermatic has a four pin spot for a spoolgun
    Los Angeles
    2,954
    Quote Originally Posted by mitchcv View Post
    Correct but not all Spoolguns work on all machines, you have to have the correct spoolgun
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
