Results 1 to 9 of 9
Hybrid View
    Feb 2011
    VA
    5
    Default another table project
    yes I to am building a welding table. i drew up some plans and am underway it's going to be 36"x72" half 3/8" plate and half 2"x2" skeleton top. 2"x2" frame for the top with 4"x1/2" thick angle iron legs. and 1"x1" frame for the storage shelf. i'm using 1/2 bolts for adjustable feet.
    first issue i have run into:
    i have a 3'x3' 3/8"plate that is bowed about 1/4 inch on one edge what is the best way to compensate for the bowing? i'm considering welding a cross brace 4'' 1/2" thick angle on the bottom. maybe forcing it with a forklift and then stitch welding it.
    I'm stuck using this plate as my top.
    Sep 2010
    Terrell, TX
    12
    Heat the plate on the bowed side along the whole length >( and then quench with water. That will draw the plate. It's not an exact science but it will get you close enough that you can hopefully flatten and weld easier.
    Sep 2010
    Terrell, TX
    12
    Just read my post again and it could be confusing. Looking at the bowed end of the plate you would heat from front to back (or back to front, your choice)
    Feb 2011
    VA
    5
    ended up welding angle to the back side.
    half 3/8 plate half 2x2" 1/8" wall tube
    2x2" 1/8" wall top frame
    4" 1/2" thick angle legs
    1x1" shelf covered with expanded metal
    1/2" bolts for leg adjustment / leveling
    Dec 2010
    Alberta, Canada
    42
    Looks like you did a fine job with the table. Well done!
    Gord
    Apr 2010
    Bronson, Fl
    168
    Looks darn nice to me. If you have the material and the time I would add a catch tray under the open part of the table to catch small dropped parts and to keep slag and grinder dust from accumulating in stuff on the shelf. But it is a really nice table, well though out and executed. Keep up the good work.
    Bob
Tags for this Thread
