Results 1 to 8 of 8
    Jan 2009
    Whitehorse, Yukon
    279
    Default Playing with TIG
    Okay who's got trinkets and/or junk welded together that they wanted to show off? Ever try to weld something together just to see if it could be done? Lets see what's out there...
    Big Blue 400D
    Trailblazer 302
    Miller S-32 suitcase
    12VS suitcase
    Lincoln LN-7 (BIG suitcase)
    Victor torches
    Lincoln 350MP with 35' push-pull gun
    Lincoln PrecisionTIG 375
    Spectrum 1000 plasma cutter
    Nov 2009
    houston pa
    104
    if im in the to see if it can be done mode i generally look for a beautiful intellegent woman that earns at least 5 times as much as i do.
    Dec 2010
    Alberta, Canada
    42
    Nice work on the beer cans. I have no trinkets to show off but you have got me thinking. Hmmmm....
    Gord
    Dec 2010
    Spicewood, TX
    5
    I hate how badly aluminum warps! You been practicing a bit.
    Best
    Jan 2009
    Whitehorse, Yukon
    279
    Here's one more I just finished-- a vanity license plate for a fisherwoman I know:
    Big Blue 400D
    Trailblazer 302
    12VS suitcase
    Victor torches
    Jan 2011
    18
    my attempt at razor blades
    some quarters, weld really weird
    Spiderweb out of welding rods
    Jan 2009
    Whitehorse, Yukon
    279
    Nice, use a little less heat and faster travel speed with the razor blades-- I had the same problem when I did the first couple. I use .032" lock wire as filler and a lay-rod technique. Filler is 3 times the thickness of the blades so by the time it melts they are already starting to disintegrate,
    Big Blue 400D
    Trailblazer 302
    12VS suitcase
    Victor torches
    Feb 2011
    21
    Cool bike and fish! Now you got me thinking!
