Results 11 to 13 of 13
    3,658
    My TV came with small tabs bolted to the back that you hang a wire thru like a picture frame. But they wouldn't work for me. You could bend a 1/4" rod like this o^o with some heavy washers welded on the ends to bolt thru, that would be pretty good if it was hung into a stud. Just a thought...Bob
    3,658
    Another way would be make some wide u brackets from 1/4" x 2" one to screw into the stud and the other to screw into the tv. Then the bolts would be easy to bolt the 2 brackets together. Use 2 brackets on the tv one upper and one lower....Bob
    143
    I would only mount a tv on the wall if all the cables would be hidden. Here is one I built for a guy in Cali.
    construction photos here:
    http://www.flickr.com/photos/weldhou...7620719728080/
    '11 Lincoln Power Mig 216
    '10 Syncro200 TIG runner
    Scotchman CPO 350 LT cold saw w/ AMS
    6x6 Enco corner notcher
    Weldsale fixture table 3x5
    Acorn Welding Platen 5x8
