Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    northern NJ
    1,880
    Everything that others have said. Buy a stack of replacements, they are cheap. I clean mine with my hand, my glove, my shirt, etc., whatever is fastest. When they get to really scratched I put new ones in. Sometimes I can't believe the difference when I change the clears.
    MM250
    RCCS-14
    Oct 2007
    2,949
    Default "Anti-Fog"
    Quote Originally Posted by kraythe View Post
    Greetings,
    I am having a big problem keeping my lenses clean on my miller digital elite helmet when doing SMAW or FCAW. I was wondering if anyone could offer any tips. It seems like after a short time (often only a couple long welds) the flux has built up on the lens so much that it makes it hard to see the puddle. Perhaps its my head position or weld position that is off. I am not a pro welder, just a hobbyist, so I am most likely doing something wrong. When using FCAW or SMAW, I find I **** my head to one side and get pretty low to see the puddle and what it is doing. I tried backing off but then the MIG gun obscured the weld puddle and I was practically welding blind with ... predictable ... results.
    So anyone have any idea what i am doing wrong or is this a common problem that someone knows a good tip on?
    Thanks in advance.
    Torch Wear makes an "Anti-Fog" lens cleaning paste that you apply to new lens covers, and helps significantly. I use my old trusty Fibre-Metal Pipeliner hood for SMAW, FCAW, and CAC-A, and save the $$$$$ Miller Hood for GTAW and MIG. The lens covers can get expensive for those "Big Window" hoods.
    I think Cyberweld sells the Torch Wear Lens paste.
    "Bonne journe'e mes amis"
    Feb 2009
    146
    Default I'm Blind
    Take your face out of the Puddle
    They gave you arms so don't have to put your face in the puddle.... Increase your face to puddle distance by the length of your arms
    Bobcat 225
    The rest is bright RED "Tig & GMAW"
    Just got a new Hypertherm 30
  4. #14
    Feb 2007
    West Farmington, OH
    746
    Hillbilly69,
    That's good advice provided you can see at that distance. Myself if I weld that far away I can't see well enough to weld.
    As davedarragh has said I only use my "Big Window Elite" for TIG welding. For everything else I use a 25.00 Jackson helmet. By the way the new Jackson headgear is a big improvement over the original.
    The clears for the Big Window Elite are expensive in my opinion but the clears for the Jackson are cheap, I think I pay somewhere between .50 and .75 a piece for them.
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
  5. #15
    Umatilla OR
    12
    Default Miller Elite
    Love My Elite for years. The only problems I have Is the inside cover. While changing lenses out its hard not to mare the very sensitive inside lens. I gently on a clean surface carefully install then put scotch tape around sides to keep grinding dust from getting in between the auto-darkening and cover lens. The outer cover gets gets wiped on my sleeve a lot but too much arc splashes makes it hard to see as i tig. That is when I Know it is time to replace.20140219_090224.jpg
  6. #16
    Feb 2012
    Wa
    600
    I know what you mean. I go for a while without changing my lens protector then when I finally think to the next bead is always way bright and like HD clear.
  7. #17
    Apr 2013
    Southeast idaho
    30
    Default Keeping Hood Lenses Clean when Working with SMAW or FCAW
    Try getting a cheater lens for your helmet. ( magnifying lens) that should help so your not holding your face as close. Or try reading glasses.
  8. #18
    Apr 2013
    metro Detroit
    91
    When I know I'm going to be welding a lot that day, I have a micro fiber rag in my back pocket (at least near by). You can get them at the dollar store. It's not going to stop all of the scratches but it's got be better than using your shirt. Or just lick it clean ;-)
