Results 11 to 14 of 14
    ****inson ND
    557
    Talking
    Ok, I see now thanks.
    Feb 2010
    Winnipeg
    29
    Default Pigtail
    Hello,
    just wondering, from all other threads I've read,
    it seems it says the round pin on the male plug is your ground, not the L shaped one, (the L one is the neutral)
    if i'm wrong, I hope someone corrects me.
    thanks
    Mar 2010
    10
    You're right. THe round or "D" shaped prong is the ground which is wired to the green or bare wire. THe "L" shaped prong on the bottom is the neutral which is wired to the white. The neutral is code now to allow dryer manufacturers to elimnate having to put transformers in the dryers to step down to 120V to run the electronic circuits in the dryer. As mentioned before, the ground is not a normal current carrying conductor whereas the neutral is expected to carry current. In fact, wiring the ground to neutral or neutral to ground can cause you to get shocked by touching any grounded appliance as this would put a 120V potential on the ground circuit which is wired to the external case of every UL listed appliance.
    Feb 2008
    897
    The round "D" shaped pin of the NEMA 14-30 plug is GROUND
    The L shaped pin is NEUTRAL.
    Do not connect anything to the L shaped pin when wiring a pigtail!
    BTW, 8 ga wire is extraordinary overkill. This welder will be running around 20 amps at low duty cycle. 12 ga is more than adequate, unless your extension cord is 100 or more feet long, in which case you may consider 10 ga to minimize voltage drop.
    And no, wiring the neutral to ground will not cause 120V to be present on the chassis of the appliance. It will cause maybe 5 VAC (give or take a few) to be present at high loads. The only way 120V would be present is if the ground was cut in the box.
    But you will feel 5 VAC and under certain circumstances it can kill, especially the elderly and those predisposed to certain cardiac arrhythmia.
