Results 1 to 2 of 2
    Jan 2008
    1
    Default Little help regards Syncrowave 300
    Got an older Syncrowave 300....built in 1985, Single Phase...and want to hook it up 230 Volts.
    The manual shows hook up is 2 hots.....My supply is 2 hots, a neutral and ground.
    I can figure out the ground...but what should I do with the Neutral wire?
    Anyone out there familiar with this older machine?
    Nov 2007
    Ontario, Canada
    72
    The neutral is not used in your application. The grounded conductor is attached to the frame of the machine. There should be a lug for this purpose close to where the two hot wires connect.
    XMT-300 with S-64 wire feeder.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter.
    Miller Spoolmatic-1
    Miller PC-300 pulser
    Miller Optima pulser
