To connect an Miller Coolmate 1 water cooler to a Miller Syncrowave 200 you will need 3 additional parts.
OK...Figured it out.
In addition to the solenoid adapter, and water cooled torch, and water cooler
You will need these 3 parts for connecting a Miller Coolmate 1 water cooler to the Miller Syncrowave 200.
ONE R/H female to female 5/8-18 coupler to hook the gas hose from the regulator on the argon tank to the short hose on the adapter/solenoid gas out connection.
ONE L/H coupler female to female 5/8-18 to connect the short hose from the adapter/solenoid to a 3 foot hose to the water return on the cooler upper fitting/
ONE 3 foot water cooler hose with 5/8-18 L/H male fittings on each end. 1/4 inch barbs and 1/4 inch hose.
Part # coupling female /female AW430
Part # coupling female/female AW 431
And water return hose with two male L/H threads 5/8-18
You are done!
NOTE:
If you are putting the Coolmate 1 on the BOTTOM of the machine you may still need a short hose to connect the water cooler to the solenoid/adapter.
This is the CORRECT Diagram.
Results 1 to 1 of 1
02-02-2011, 01:50 PM #1
Connecting a Coolmate 1 to syncrowave 200
