Results 1 to 10 of 12
Thread: Pipe Notcher
    May 2010
    Central CA
    711
    Default Pipe Notcher
    I have seen a lot of threads looking for pipe/tubing notchers. My friend has this one and used it to build a fence.
    http://www.lowbucktools.com/notcher.html
    Good Luck,
    Bob
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    30A w/ WC-24
    HF-251D-1
    Select Lathe
    Exact Mill
    Spectrum 625 X-TREME
    Cutmaster 152
    Kalamazoo Band Saw
    SX60 Arc Station
    FX30 Arc Station
    8-Grinders
    5-Victor O/A
    4- Chop Saws
    2-Drill Presses
    Lincoln SA-200 Blue Tint Red Face
    Lincoln SA-200 Red Face
    Apr 2010
    Jackson, MS
    74
    I just used mine a ton. http://www.vansantent.com/tube_copin...ines/TN250.htm - A bit pricey, but if you have the money and want some good equipment it is definitely worth it.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Spectrum 625 X-Treme
    Dayton 6" Miter Band Saw
    Delta Drill Press
    Bosch 10" Table Saw
    Jet 5 Ton Chain Hoist
    Radnor O/A
    Nov 2010
    Arkansas
    41
    I looked very seriously at the LowBuck when I was looking for a notcher. I chose to go with a JM2 Notch Master instead. The reason was that the LowBuck dies were just too expensive to keep on hand in order to cover a decent range of different tube diameters. With the Notch Master I can afford to keep just about every size of hole saw that I can find and they are not expensive, and I don't buy the cheap crap either. They do a really good job and if you keep them lubed when you cut they will last a very long time. My Notch Master is a MUCH less labor intensive tool too, which says a lot when you get to be my age!
    Stephen
    Millermatic 251
    Miller Syncrowave 200
    Miller 30A Spool Gun
    Hypertherm PowerMax 30
    Etc., Etc., Etc......
    Western Arkansas Welding
    Lodi, CA
    1,127
    Bob,
    Is this still available? What size dies? Condition and cost?
    I'm in Lodi, probably 1/2 hour 45 minutes away from you, PM me if necessary.
    Sep 2006
    270
    I recommend the Low Bucks. The one I have I bought back in 1989. I have it set up for 1 1/4 and 1/2 inch pipe. I use it when I need it and it still works good. I used the two inch (2 3/8" O.D.) for lightwall for years. Then I bought the Vogel and I use it for all my 2 inch pipe.
    In fact I used the Vogel today. I'm making a gate, five rail 2 3/8" O.D., nine footer. It's to replace the one that jumped out in front of a bud's Mercedes when we had the icey roads. It's sixteen gauge .065 galvanized fence tube.
    Dec 2008
    Fort Worth, TX
    28
    Thumbs up
    wroughtnharv I like your license plate and mud flaps!
    alabama
    718
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    Lodi, CA
    1,127
    Edit to my previous post:
    Somehow, for whatever reason, I read the original poster's intent as trying to sell this unit. Probably because I am in the middle of a job, where I will need to be notching pipe out for handrails.
    I realize now, the only intention of the original poster, was to get a discussion started about notchers. My bad, and I apologize for jumping to conclusions.
    Carry on, I for one would appreciate more discussion about different brands, especially the ability to make angled notches, I have several ramps to make, not all joints are 90 degrees. As I deal with this problem often, I have various ways of doing it, but it would be nice to have a helper simply cut the angle, notch correctly, and just weld. The notcher I have available right now to use, can simply make 90 degree notches, costs time and money when doing ramps.
    Deltaville, VA
    2,241
    JSFAB,
    Check out the "offerings" by JD2.
    They're "hole saw" based, but have done an excellent job for me for years.
    They'll do angle notches as well as "offset" notches.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Default Notch Master
    I have been using the notch master for a few years now, and love it. It has good capacity. Will do alot more than my ol joint jigger. I was sold on the being able to offset cope notch. I bought it from Van Sant. Good price and good people. I use the notch master for mostly sch 40 pipe. I notch dry and slow. And have been using the same few hole saws. I do lube em up when notching anything else. They'll burn up in no time otherwise. I haven't used my ol joint jigger since i bought the notch master.
