    Jul 2007
    Lancaster, Pa
    431
    Default Super Abrasive Welding
    I bought some 5/32 super abrasive electrodes to add some hardener to one of our cast iron plow shoes to try it out before we do the whole fleet. These rods have roughly 1/4 inch of flux on them, I may be exaggerating a little but it is very thick. I never used these rods before and on the box it says to set the amps at 140 - 160 which sounds right. My question is, with that much flux, how can you tell how much of a bead you are laying or is best to run a practice bead ?
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Fraser Valley, BC
    593
    I would just run a short practice bead to get a feel for the rod and the setting, better than testing on a good workpiece. This is what I do whenever I use a new type or size of rod.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Jan 2008
    Jayton, Texas
    12
    hard surface rods run similar to 7018. Make sure you have a very clean surface to weld those high dollar rods to. I usually run a pass of 7018 before I start hardsurfacing. Seems to leave less pitting.
    Jul 2007
    Lancaster, Pa
    431
    Thanks guys, I ran a practice bead today without preheating to give it a try. Ran a bead across a junk brake caliper at 170A so I think with a little preheating, it should be pretty simple.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    2009 FXDC
    Sep 2006
    Abilene, Texas
    639
    Quote Originally Posted by robphillips View Post
    Good tip! I've never done it, but I can see how it would not only lay a good clean base for the HS rod, you also build up a little thicker layer of new metal.
    Jim
