Results 1 to 3 of 3
    Dec 2009
    722
    Default More Caterpillar projects
    This a hydraulic heat pump. It was the only descent spot to mount it, very tight fit. The heat exchanger fitted good by the radiator compartment "" An other tight fit.
    Jan 2011
    6
    another add on and not just a relocation? pigpen
    Dec 2009
    722
    It's an add on, the guy bought the machine new and wanted this heat exchanger installed before taking it home.
