Results 11 to 15 of 15
    Dec 2009
    Melbourne, Australia
    87
    Is the second pic the finished weld? If so, doesnt the weld section need to be relative to material thickness?
    It seems thick for a single pass or no bevel. It also cold be my eyes.
    Kemppi Pro Evolution 4200
    Kemppi 530 wire feed with MXE panel
    Kemppi ProCool ( coming soon)
    Cigweld TransMig 210se
    Cigweld TransTig 200 AC/DC
    Hypertherm PowerMax45
    CutSkill O/A setup
    Speedglas 9000x adflow
    Speedglas 9100xx
    Dec 2009
    722
    It's about a 3/8 legs for the bead and the gusset is 3/4 t-400. It's to help stabilise the front idlers.
    I finishing installing the blade stops 3"X6"x10" with a radius on the same machine. And it only calls for 3/8" legs on the bead and 1.5 " run off ""feather to ctick that big block to the side of the blade mount frame.
    I'll post pictures of it.
    KANSAS
    511
    I've heard that a fillet on both sides only needs to total 75% of the thinner base metal thickness.
    3/4'' x 75% = .28
    Thats why 1/4, 5/16, and 3/8 fillet sizes are the most popular. It takes a big chunk of steel to require more than a 3/8 fillet on both sides. Especially if you figure in the effective throat.
    '08 F-350
    Vantage 400
    SA-250
    SA-200
    Invertec V350Pro
    Invertec V205T-AC/DC
    Miller 12VS suitcase
    Miller spectrum 2050
    Pipe beveler's
    Track torch
    Dec 2009
    722
    I actually put a couple passes. Didn't remember,"" multi-tasking a lot these days""
    And some cylinder guards
    Dec 2009
    87
    Thanks for the clarification
    CutSkill O/A setup
    Speedglas 9100xx
