Results 1 to 10 of 13
    Angry Plasma cutting pointer
    Hello all, I wanted to get a couple of pointers for making cuts with my plasma (spectrum 625). I was making cuts in some 12 ga. mild steel (using a guide) and I kept getting this "sticking" feel, but I'm dragging as smooth as I possibly can. The cut turns out like crap (for plasma) and it requires too much grinding to clean up! Any tips would be greatly appreciated.
    Indiana
    541
    I use a stand off for most cuts. The cuts are cleaner and the tips last much longer.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Dec 2005
    Dallas, TX area
    267
    Default Plasma tips
    Remember: If the sparks are shooting straight down, you're moving the torch too slowly. If the sparks bounce back, you're moving too fast. You will be hard pressed to cut 12ga too fast. The sparks should come out of the bottom at approximately a 15 degree angle. Good luck.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Queens NY
    1,547
    what is available for stand off other than the roller guide?
    i just bought a drag tip setup but it doesn't provide any stand off like i thought it did, what's the point ?
    Indiana
    541
    My Thermal Dynamics came with one, I assumed they all did.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
    gate city virgina
    213
    well you could use a roller guide but they make some thing akward. or just hold it by hand a bit above the metal thats what y buddy does of course sometimes we have to do some grinding to touch up stuff but hey it works.
    Nov 2005
    130
    Default Door Chart ?
    On my mig welders there's a door chart that tells you how many amps to use for the thickness you're welding.
    Is there a chart somewhere that tells you how many amps to use to cut the thickness of metal you're cutting with plasma ?
    Cave Creek Az
    1,051
    Use a guide for cutting straight, piece of 1/8"x1" hot rolled is fine. Clamp it in place then run a piece of soapstone back and forth across it. The soapstone lubricates the drag tip and lets it glide across the cut. Also, a light touch is required.
    Laiky, what kind of machine do you have?
    Queens NY
    1,547
    Spectrum 375
    a light tuch and proper speed dose the most to keep it on track and cutting nice. i use a wire brush on my tip inbetween cuts to keep it clean, that might help with it sticking. lots of slag means too slow of a cut speed usualy. takes a little getting used to to learn the best speed for the matereal. after that its all good.
