Results 1 to 3 of 3
    mpoteete Guest
    Default Pulse capabilities
    I have a MM350P that I am using to weld 1/2" bar to 3/16 angle.
    I will be using the welders to join I- Beams to 3/4" plate.
    I have been reading some on the Pulse feature and it sounds interesting. I read all of the advantages for welding Alum and sheet metal. What are the advantages on thicker stuff?
    Mike
    Aug 2007
    Seattle,WA
    55
    I've herd from a Miller rep that you don't want to pulse over 3/8" on aluminum, but I may be wrong. I thought the pulse feature was geared towards thinner stuff anyways.
    Welders do it hotter!!
    www.Munsonworks.com
    Mar 2007
    ****inson ND
    557
    Talking
    Quote Originally Posted by mpoteete View Post
    Mike
    Out of position spray arc.
