Results 1 to 3 of 3
    Jul 2010
    central Kansas
    66
    Default aluminum tank fix
    1/8 and 3/32 rod 105 and 85 amps rod cant remember the brand
    3/16 sheet in the tank and for the patch
    Got a call from customer first thing this morning "we had a little oops this morning can you come by and see if you can fix it?"
    The patch wound up 3 ft tall and 8 ft long.
    I havent ran much stick alunimum at all but the customer was in a bind.
    These trucks haul feed for cows and with snow on the ground around here that is a high priority.
    Very interesting stuff to run.
    Enjoy
    Jul 2010
    central Kansas
    66
    Aug 2007
    arkansas
    781
    thanks for the pics.... nice to get some winter work in, its very valuable for this season..... tough repair.... ive never liked smaw on aluminum....
    welder_one
    www.sicfabrications.com
