Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Jul 2009
    Pampa,tx
    30
    Quote Originally Posted by atc250r View Post
    Very difficult to open root with stainless smaw. Especially 6G. TIG is a much better (and common) choice for open root ss.
    So are you saying completely different technique from a 6010 root pass?
    Apr 2009
    362
    Quote Originally Posted by iran8gold View Post
    Yes
    Aug 2010
    VA
    86
    Default iran8gold
    what atc250r is saying is not a different technique but a different process.
    root and hot pass tig with purge and then stick to finish
    old but new
  4. #14
    Thumbs up
    Thanks to you all really.... I got the settings with amps and 3/32 and once i got the feel on some practice pieces i was able to get it done rather well. I agree with Sundown 100% would have been alot better with MIG. I ran a series of root passes with a Lincoln Red Baron 3/32 rod. Guys if youve never used these TRY THEM they make life so much better and very little slag to deal with. Then i capped using a series of stacking weaves it came out great. Ill try to get pictures up soon. Thank you all again and the amp advice helped big time....Cheers to you all..
  5. #15
    Mar 2013
    1
    Default For 309 rod what is the best polarity?
    I bought some scrap stainless to refine my technique and tried with both positive and negative electrode. The positive almost seemed better. Am I going the right direction? Also I read the heat is about the same as 6010 and that seemed to work well. Any particulars to help? So far I am using 3/32 but have some 1/8 to work with also
  6. #16
    Sep 2009
    Canada
    193
    Certanium makes a great fast freeze stick rod for smaw welding out of position. Only problem with them is the cost and they are not certified for code work.
    Lincoln Idealarc 250 stick/tig
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Owner/Operator Devlin Metal Works
    Custom CNC Plasma Cutting and Welding
