Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
  1. #41
    RAPID TAP is my cutting fluid of choice!
  2. #42
    Nov 2013
    Toronto
    46
    Default What are the best drill bits
    I use the Walter SST bits, they're the best bits I've used in my 28 years.
  3. #43
    May 2014
    Quote Originally Posted by jcb View Post
    What drill bits are best to get if you are drilling metal ? I've seen Titanium, Zirconium Nitride, Cobalt, H.S.S. Some indicate "high speed", some are coated with the above metals only. I do know that some are much more expensive and stay sharp longer than others but I have no idea what type they are. Is price the only deciding factor ?
    JCB
    Carbide-tipped bits are generally the most expensive but they are supposed to stay sharper the longest, more so than the titanium H.S.S and the others.
  4. #44
    Dec 2010
    295
    I still am using a set of kobalt bits I bought 5 years ago.the day I bought them I also bought a drill bit dr bit sharpener .I paid 50.00 for the sharpener and sinse then it has paid for itself 100 times over.
  5. #45
    Apr 2011
    12
    The drill itself isn't the most important part. Knowing how to keep them sharp and how to use them properly is the trick!
