Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
    Indiana
    541
    Yep I have cut 3 1/2" holes in 1/2" plate using a hole saw with my drill press.
    But even using a hand drill ,speed and feed. I use a hand drill for tapping holes also, 4-40 to 1/2 inch. Too lazy for hand tap wrench.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Nov 2007
    West Georgia
    103
    Default hand drill tapping
    Quote Originally Posted by tnjind View Post
    Wow, that sounds pretty bold. I imagine you broke a few trying to get the feel of it. Or, maybe you have very high quality taps. I recently did 16 3/8 in. holes for a set of casters. That did get old. I was really afraid I might break my cheap Lowes tap even doing it by hand.
    Indiana
    541
    Been doing this for a few years, I did break a few, its all in the feel. I use cordless drills, 18volt or bigger. I have Porter Cable 19.2 that is a real workhorse. I am on the second chuck, I use channel locks to tighten it with 1/2 taps.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
    Sep 2006
    Abilene, Texas
    639
    I've got a couple of sets of older Craftsman HSS bits up to 1/2" that have been decent to me. I've got other various ones up to 1". I do keep them sharp and don't burn them up with speed. Keeping a bit sharp is the key to success. No cutting tool works very good when dull. Sharpening a bit isn't difficult if you own a bench grinder with a fairly fine wheel on it. I use the side of the wheel and duplicate the angle of a new bit. If you don't know what that is, go get a new bit and hold it against the wheel to get the idea. Use water and don't burn the bit up on the grinder! If you keep them fairly sharp it doesn't take much to touch them up and keep them like new.
    Jim
    Indiana
    541
    jim-TX just like chainsaw, keep it sharp and sharpen often.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    HH135 mig
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    Harris torch
    beer fridge
    Vancouver, Washington
    51
    I have two sets of Chinese made Zirconium Nitride bit sets one I bought about 3 years ago at Costco. I think it has Master Grip printed on the front and another I just recently purchased at HF. Both sold for around $50.00us and appear to be the same bits. They have approximately 100 bits in fractions, wire gauge and letter gauge. Very handy for matching taps with drills. The Master grip set has been very durable and the bits stay sharp for a long time. I drilled 112, holes in 1X2 steel bar for a shelf pin hole guide. I also have a Dewalt set that has not been as durable as the Chinese made drills. The Chinese drills are all different lengths, if you compare different sets next to each other the drills of the same size will often be different lengths. I believe these sets are made up of industrial drills that have been re-sharpened and re-coated. Not sure but it makes sense to me and would explain the high quality steel at such a low price. As said above speed is very important, slower for larger dia and faster for smaller. Plenty of coolant/lube for steel. Aluminum is not a coolant critical as long as the bit is sharp and cutting in new material each revolution.
    Paul
    Alberta Red Deer
    373
    well for the bits i buy viking tools bits but once again have to keep sharp and use the right pressure. as for cutting oil i use rapid tap for general holes but it does not weld well. water soluble oil that u use in ur band saw for holes that get welded that cant get a clean up, but my trick for lots of holes in thick material i use kerosene. yes it does work freaking awesome its a old millwright trick. one 1/2 in drill bit drilling 2.5" thick material lasted 35 holes not bad for a $30 bit.
    trail blazer 302
    hypertherm plasma
    millermatic 251
    high feq. arc starter
    suit case (extreme 12vs)
    o/a torches
    Queens NY
    1,547
    i think the chinese bits in the huge sets are very brittle. they cut well and last long but i did hang one up (3/8") and one side of the tip snapped clean off.
    i have several sets of bits but my go to set is an irwin from costco and they have lasted very long with care. for steel, slow speed and high pressure. if you getting curlies and there not blue your doing well.
    Fraser Valley, BC
    593
    At work they used to order two types of drill bits (don't ask why... ), some were cheap junk and the others were TiNi coated Norseman bits. The Cheapies usually lasted about 10 holes with a hand drill and that was about it. The Norseman's would go for a very long time as long as you didn't do anything stupid, but the do cost a lot more.
    Bit speed is crucial to making fast, efficient cuts and helping extend the life of the drill bit. I recomend finding a speed chart from a manufacture or reputable source, just remember slower is not always better. Running a 1/4" drill bit on the slowest speed only prolongs the agony of drilling the whole and wears the bit out faster.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Mid - MIchigan
    37
    Default homier drills
    this bit is from an outfit that shows up in town every now and then and sets up for a few days and sells tools and whatever. This bit was used to drill holes in wood for picnic table seats. The guy hit a steel brace on the other side of the wood. He was using this in a battery operated drill. When I saw it I thought it was some specialty drill. Silly me.
