Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    354
    Default Sheet Metal Adhesive?
    I got a call from a local business as they are wanting to renovate their kitchen/coffee room. They want a polished stainless steel backsplash, which I can provide them, no problemo there, but I am having trouble finding an adhesive to attach it to the wall. Thinking of using about 20ga material. Awhile back I tried something from the lumber yard that was intended for metal studs, but it didn't really work well for sheet metal. Screws are outta the question for aesthetic reasons. Any ideas out there?
    Nov 2008
    Colorado Springs
    272
    3M makes a contact adhesive that works really good metal to wood. 1300L is the number.
    I buy the stuff from McMaster-Carr. I use it for metal to rubber for aerospace applications. not that expensive though.
    It got the blessings of the engineers because it won't let go.
    Good luck
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    3,650
    Pure silcone works well also...Bob
    Dec 2010
    yuma az
    66
    Default hmm
    i would also suggest the contact cement 2 things make sure the wall is as smooth as you can get it and has atleast a primed surface lilke oil based kills or zinser dont go over unprimed drywall mud and second go to the hardware store and get a laminete roller http://www.google.com/products/catal...ed=0CGwQ8wIwAQ or even better http://www.google.com/url?sa=t&sourc...2k3C5SBQpS184w have everything ready when ya put it in place cause once those the 2 glued sections meet theres no going back then roll it and your good
    arkansas
    781
    when i worked at the sign shop, we would sometimes get the specs for sheeting to not be welded to the framing or couldnt because of the lamination scotchlite... 3m makes a 2 part glue (i'll find the part number in a min) once the glue was applied and allowed cure time, i tried to pull 2 peices of 6061 square tube apart with a big truck n forklift (yeah, i live in arkansas, "hold my beer n watch this ya'll") it held to the point that it actually ripped the side outta the tubing.... it was 3x3 1/4 wall tubing... now to find the stuff...
    http://www.shop3m.com/62264512328.ht...thane-Adhesive
    i had no idea that it was that expensive, but it really works
    welder_one
    www.sicfabrications.com
    Dec 2010
    yuma az
    66
    Default hmm
    whew doggie that stuff is pricey dont get it on your hands or anything else ya dont want permanently stuck
    3,650
    Quote Originally Posted by welder_one View Post
    Now that's funny ...Bob
    1,565
    When you install it have the bottom supported from dropping straight down. This way the glue only holds it from tipping forward & does not have to support the weight of it. The adhesive might hold it to the paper on the drywall fine but I've seen the paper tear away from the drywall with heavy objects like mirrors, etc.
    May 2008
    Mpls, MN
    464
    Make sure the back is not polished and just use a construction adhesive from the local home shop. That stuff is so strong you will pull chunks of sheet rock out before the glue breaks. Plus it is cheap, and I know that they have one for metal but I don't have any right now to be able to tell you what it is.
    -Dan
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
    354
    Quote Originally Posted by engnerdan View Post
    -Dan
    The back won't be polished, just standard #2 dull finish, although very smooth. The last stuff I used was for metal studs but wouldn't adhere well to the smooth surface of the sheet metal.
    Some other good suggestions there, though. Thanks
