Results 1 to 10 of 11
    Jan 2011
    Default welding vertical with a mig welder
    i am new to welding and would like to perfect the art of welding vertical is there any one who can give me some hints or secrets or ideas so i may perfect the art of welding vertical thanks to all who reply cato
    Nov 2009
    houston pa
    104
    Nov 2010
    Arkansas
    41
    I think my favorite weld is a vertical down with a mig gun. I run the same settings as I do for flat welds and use a backwards "c" movement with the arc. Some like to go down in power a bit for out of position welding but I like to keep the same settings and move just a bit faster.
    Stephen
    Millermatic 251
    Miller Syncrowave 200
    Miller 30A Spool Gun
    Hypertherm PowerMax 30
    Etc., Etc., Etc......
    Western Arkansas Welding
    2,949
    Default Flat and Horizontal
    Quote Originally Posted by crazycato View Post
    If you're new to welding, perfect the art of flat and horizontal (grooves & fillets), and then graduate to verticals.
    Invest in a GMAW Handbook. There's usually an enitre chapter dedicated to OP welding.
    There's just too many variables and scenarios to cover in one answer.
    "Bonne journe'e mes amis"
    Jan 2009
    Whitehorse, Yukon
    279
    Amen to opening a book. There are no "presto-chango" answers on here to get you started. That's what textbooks are for.
    Check out the Lincoln Foundation's "New Lessons in Arc Welding". It will guide you step by step through every type of weld for mig, stick and tig. Lesson plans include weld procedures, amperage settings, everything you need to get started
    Big Blue 400D
    Trailblazer 302
    Miller S-32 suitcase
    12VS suitcase
    Lincoln LN-7 (BIG suitcase)
    Victor torches
    Lincoln 350MP with 35' push-pull gun
    Lincoln PrecisionTIG 375
    Spectrum 1000 plasma cutter
    Jan 2011
    Default thanks
    Thank you all for taking the time to help me I will get the book as soon as possable but if any can think of anythig else please post
    Jan 2009
    Whitehorse, Yukon
    279
    Check this page out, he's got some good techniques that should help you get started:
    http://www.weldingtipsandtricks.com/...l-welding.html
    Big Blue 400D
    Trailblazer 302
    12VS suitcase
    Victor torches
    Jan 2010
    chugiak, alaska
    26
    Default tricks of vertical
    best trick there is is practice and lots of it
    330 a/bp
    211 w/ 100 spoolgun
    lucky's ss digital elite
    victor o/a
    milwaukee tools
    Aug 2004
    Milan Michigan
    1,808
    Goinssr.
    You should get iut of the habit of doing vertical down welds, Verticle down welds have a tendancy of getting bad penetration because the molten puddle rolls down into the weld.
    Vertical down welds are typically good on thin sheet metal but not good for heavy plate.
    There are some processes that call out for vertical down but if your not skilled enouph to stay in front of the puddle you may get a weak weld.
    When doing a vertical up weld with mig it is common to turn your machine down because its a high deposition weld which builds alot of heat into your work peice.
    Jan 2011
    Myself and some of the guys needed selfshielding FCAW,AWS certs.Our setup with a miller shopmaster is as follows; Lincoln nr 212 .045,DCEN,150ipm,19-20v. New contact tip(s),new liner,and clean plates. We welded vertical up,with execellent results,and three of us passing the bend test.
