Results 1 to 8 of 8
    3,651
    Cool Royal 44-30 Premium Nickel-Iron-Manganese Mig Wire for cast iron.
    I just bought 2# spool of .035 Crown Alloys Royal 44-30 Premium Nickel-Iron-Manganese Mig Wire (ER NiFeMn-CI) to use with my Mig on some small castings that need built up. Figured i would give it a shot and take some before and after pics. The 2# spool was 75 bucks so it will be an expensive test but i have wanted to try cast and mig for 35 years. You can use CO2, Argon, or 75/25 gas and i have all 3 to try. I have some lathe parts to do then they wil be ground back to shape after filling the marks with weld. Pics tomorrow...Bob
    27
    I've been using that wire for many years to repair cracked engine blocks, cylinder heads, manifolds, etc. and it works great.
    I've only had trouble MIG welding cast iron once. I was trying to weld up a crack on a very old exaust manifold and no matter what I did I couldn't get the weld to stick. I think that the manifold around the crack was too contaminated with exhaust by-products to let the weld stick.
    But other than that manifold, I have successfully welded many many cast iron things using that wire.
    Miller Dynasty 200DX TIG
    Miller Coolmate 3
    Miller LMSW-52 Spotwelder - (Still Going Strong )
    Lincoln Sp-175 Plus MIG
    Miller Digital Elite Helmet
    Miller Elite Helmet
    Speedglas 9100xx w/ADFLO Helmet
    3,651
    Thats great to know on the wire. My welding table has 4" of snow on it so it may be another day or two...Bob
    Chico, Ca.
    315
    novel idea Bob... precooled cast or high gas bill for preheating. you got the snow but we got the water. i thought i was going to have fire up the boat to get to the shop. found out rubber boots and welding don't go hand in hand. i'm interested in hearing your feedback as all i ever use is stick to weld cast....jim
    miller 225 bobcat
    miller aead200le (with miller hf tig trailer mounted)
    mm175, mm211, TA181i
    mm252 w/30a spool gun
    precision tig 225
    hobart stickmate LX ac/dc
    Speedglas 9100X & XX / Miller Digital Elite
    hypertherm 380 & cutmaster 52
    victor journeyman & super range
    ridgid chop saw, kalamazoo band saw
    steel max and evolution carbide saws
    6 4.5" & a 20lb 9" rockwell grinders
    case 580 backhoe (for what i can"t lift)
    if first you don't succeed
    trash the b#####d
    3,651
    Quote Originally Posted by jbmprods View Post
    Thats all i have used for the last 35 years is stick. My fav rod is Crown Alloys 255 but i have been dying to try mig for the last 30 years just didn't have the wire...Bob
    Aug 2011
    13
    I hate to bring up such an old thread.
    With this wire coming in a 2 pound spool, how big is the center hole of the spool? Well these spools fit a normal 2 inch spindle?
    Thanks in advance!
    3,651
    Quote Originally Posted by Spotted Horse View Post
    Thanks in advance!
    It is a 5/8" hole. Can you take the plastic spindle off and there is a 5/8" bolt under it? I made an adaptor for my small spools....Bob
    Aug 2011
    13
    I'm sure the plastic spindle will come off, there is tensioning nut.
    I really like your adapter, gets the spool more in line with the guide tube, and drive rolls! Digging around a little I see Lincoln even sells an adapter for the 8-inch spools. Doesn't look like it has as much extension as yours though.
    Thanks so much for the fast response.
    http://www.lincolnelectric.com/en-us...x?product=K468
