Results 1 to 3 of 3
Thread: Reels
    Default Reels
    Just wondering if anyone has any plans for reels or wants to post some pics of theres.
    Feb 2008
    los angeles, ca.
    63
    Quote Originally Posted by AmericanWelder View Post
    here are the pix's of my, I made then my self, the 002 are the rolls, the 004 is the stand extended, the 003 is the stand retracted and the 001 is the close-up of the positive (+) roll.
    Jan 2011
    Olathe Kansas
    Default Heres some pictures of mine
    I used a different approach using the tweco disconnects as i use a hi freq box and dont want any kind of jump from the leed reels to ground out anywhere , the locking mechanism is a very simple pin with a spring and a hole with a roll pin in it and two pieces of rod inside the 2 inch tubing u pull it and twist 90 degrees to unlock them and twist 90 and they lock , i have since built a oxy acet reel for the top of it
    heres a link to estimate the capacity of the reels
    http://www.airwinch.com/tools/drum.htm
    A government should fear the people....
