Results 1 to 10 of 18
    Jan 2008
    4
    Default Welding Helmets - Help
    Hello.
    I am new to this board and new to welding. In fact, I am starting a welding course at my local junior college in February. Currently, I am looking to purchase a welding helmet and could use some direction. I have tried to conduct some searches on welding helmet comparisons on Google, but have not had much luck. Three of the helmets I am currently considering are the following:
    Fibre-Metal Tigerhood 906
    Fibre-Metal Pipeliner 110
    Sellstrom 280 Series
    Any insight from you experienced and well-seasoned welders would be greatly appreciated.
    Thank you.
    earle
    Austin, TX
    621
    I don't know what the requirements of your class are, but I imagine most of us here used auto-darkening helmets.
    If you are in the US, you can get one from Harbor Freight for $50. Amazon and ebay are good sources for these masks. The Miller helmets start at about $250, but any old auto-darkening is a good choice.
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    springfield mo.
    5
    Default hoods
    pipeliner is good had one for years i have autos now they help alot dont get a solar only they blind you off the bat till they charge
    Austin, TX
    621
    Quote Originally Posted by wiliamsonswelding View Post
    Yeah, I was going to mention, the one's that have a battery backup system have a faster response time. They can be more expensive, but I have seen a few at the $50 mark.
    New Westminster, B.C. Canada
    8
    kinda depends on the process I suppose, why buy an expensive auto if you're gonna stick or wire with it? I use an old manual Jackson Shadow full size view for TIG (Gotta be 10 years old and the thing looks like new), no pitting or melts. I've spent more $$ on outside cover plates than the helmet is worth. Personally, since you're new to welding, I'd opt for a small window, flip up shade helmet. Fibre-Metal Pipeliner 110 looks like a good starter helmet.
    Miller Syncrowave 250
    6000+ hrs Al TIG
    Nov 2007
    West Georgia
    103
    Default Miller Pro-hobby
    I got through a MIG class with a flip-up shade helmet that was around $20. But, no matter how careful you are at flipping down the helmet or flipping down the shade, you'll have cases where you move off target. So, auto-darkening becomes attractive.
    tasslehawf: The Miller helmets start at about $250
    Not so. The Pro-hobby in black can be had for under $120 via Indiana Oxygen - IOC on Ebay buy-it-now. This is variable shade with battery and solar cell.
    Using this helmet is a real relief over the flip-up. I'll note, though, that Miller helmets use proprietary cover lenses and cheater lenses. I had planned on using my old cheater, but had to place a second order for a Miller lens.
    Jun 2006
    milwaukee wi
    37
    Default weld helmet for new welders
    I teach welding at a pipefitters training school, I recomend for a beginer a auto hood or drop in auto lens for the style hood that fits you best. the auto lens for the beginer really helps with starting the arc and seeing where to start welding, it cuts down the learning and frustration curve from sticking the rod. there was a article in the American Welding Society Magazine a year or so about auto hoods, the off brands like harbor freight and other cheap knock off brands do not have the optical quality that a name brand does in short they could damage your eyes. also most of the knock offs dont use they standard size clear cover plates so you will need to purchase a bunch when you buy the hood. my experience with students using the knock off auto lens hoods is that we spend more time trouble shooting them then welding, you get what you pay for. the name brands jackson, miller, lincoln and so on are trouble free.A pipe liner is a good starter hood. i have been using one for 30 years out on the job and in the classroom, but a welding hood is like a pair of boots, what is comfortable for you might not be for me my welding partner at my day job uses a tiger hood and i use a pipeliner we both use huntsman auto lenses in those hoods. when you go to pick out a hood try several on and pick one that fits you the best, some things to look for are does the style you like cover your neck effectivly, for example i have a short fat neck so the pipeliner with its curved bottom works great, the tiger hood has a straight bottom and it hits my chest when i look down for flat welding and screws up how my bifocals work.These are just my observations and opinions after 20 years of teaching welding, there are a lot of smart and experienced people on this forum and they will also offer you very good insite and options from a great range of experience and knowledge, sort thru it and find the one that works for you. hope this helps.
    WELDCKR
    Miller XMT 350
    Miller Spectrum 3080
    Hobart Beta-Mig
    Lincoln Square wave 175
    Victor Jouneyman
    Whole bunch of Dewalt stuff
    When I learned to weld back in the day, I used a cheap'ol flip up lense.
    When I got over those, I used a cheap'ol Jackson fixed lense.
    Because a company payed for it, I used an Optrel Satellite at one point.
    Currently, I use a fixed wide lense Superglas Fibre-Metal (model 680). I've never looked back. Once you get used too the "yes man," it's not too bad!
    The problem with autotints, and I'm sure it varries from make to make, is that a lot of the time the lense isn't a steady shade. It'll be lighter on the edges and darker in the center. Though it depends what you're doing, for fitting or stitch welding or tight places, an autotint is the cat's meow. Not so much if you're doing longer welds.
    Austin, TX
    621
    My Miller Elite mask came with 3 sets of replacement lenses, but I'm not sure about the less expensive Millers.
    As far as the inexpensive autos: I had a generic one I got off ebay in 2001 when I was first learning. If worked fine for me. It did fail over time.
    Having done a good amount of stick as well as tig, I think an auto for stick is just-as if not more useful than tig is far as starting an arc and not sticking. But then again, I have very little formal training (I couldn't get an arc started when I was learning in school).
    It sounds like a good bet might be to get a mask that can take a standard size shade. That way you can replace a non-auto with an auto eventually and you can get a good auto-darkening mechanism.
    26
    Default helmets
    go to millers web site and watch the vids on there helmets
    i got the elite s. and love it jackson makes a goob one to
