These are a few pics of a pusher frame i fabbed in my shop last week for a customer.All mig welded with my 250X .035 70S6 wire.Side frame plates are 5/8"thk.,pusher beam is 8"x6"x.375HSS. Uprights are 4"x4"x.25HSS.Truck will push a 11' plow.The top lift triangle is not installed the customer was still painting it along with the air/lift piston.
Thread: Mack Truck plow frame
01-02-2011, 08:30 AM #1
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
01-02-2011, 01:23 PM #2
- Sep 2005
- CT.
- 332
Nice. How far back do the side frame plates go. Are you going to make supports behind the lower part of the pusher and make "arms" back to the frame. I want to do this to my old mans International Dump and put a 12 footer on it.
Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
Bridgeport Milling Machine
South Bend Lathe
Etc. Etc....
tjsperformance.com
01-02-2011, 04:41 PM #3
Frame mounts
The side plates are about 14"-16" long on the frame.They are welded to the underside of 6"x6"x1/2"thk clips mounted to frame with 7/8" Grade 8 bolts fine thread with nylock nuts.Also the 6x6 angle is trimmed to mount to the frame where needed.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
01-03-2011, 04:56 PM #4
Does the hood still open? It looks like the mount interferes.
01-04-2011, 03:07 AM #5
01-04-2011, 11:28 AM #6
Ok. Gotcha. Thanks for the clarification. I see it now. I'm used to the ones that have the grill attached.
