Results 1 to 10 of 14
    Wetaskiwin, Alberta
    111
    Default Running Board Material
    "A customer of mine is also restoring a REO truck. He is looking for new material for the running boards. Instead of conventional checkerplate this has small squares instead. The squares are approximately 3/8" and about two inches apart. Has anyone ever seen anything like this at a steel supplier? Any ideas to put this back to original would be appreciated.
    Byron
    Apr 2008
    dallas,tx
    207
    not sure of a supplier but it could probably be done with a laser or plasma. material wouldn't have to be terribly thick as you could brace it from the underside. Programming wouldn't be obscene as it'd be a repeating pattern.
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plenty
    Houston, Texas
    23
    By checkerplate do you mean treadplate? or expanded metal?
    What you seek has raised squares or square holes?
    I've used round perforated and square and other shapes are also available. Maybe THIS is close?
    The stuff could be laser, plasma or even flame cut if cost and time were inconsequential, but it isn't. Roller punched.
    Mike
    WHEELED VEHICLE SERVICE SINCE 1960
    Lake of the Ozarks MO
    3,596
    I have seen the tread plate with the small square raised holes before. It is much better when wet than the common diamond design.
    I haven't a clue if you can even find it these days. Or if it is even still being made.
    You might find some scrap of it somewhere if you searched all over. No one can expect you to be able to source anything ever made tho.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Wetaskiwin, Alberta
    111
    Default Plate
    The squares are raised.I am not sure of the correct terminology to describe the plate. It is not expanded metsl. I am thinking that perhaps the material was proprietory so the supply may have been limited. I am hoping that someone out there may have seen it on some othere piece of equipment that may be common in the area that I am in. Thanks for the help so far.
    Byron
    Jul 2007
    241
    Maybe this company can help you www.mcnichols.com It looks like they have something similar under the ''designer metals'' section. Mike
    Chicago-ish
    282
    Quote Originally Posted by crawdaddy View Post
    Here
    Jul 2007
    241
    Spotsineyes,How do you type the word '' Here" and have it link to the item? That is pretty cool.Mike
    Chicago-ish
    282
    I did it using this method.
    Wetaskiwin, Alberta
    111
    Default Material
    I have one of the local scrapyards keeping there eyes open fof any of this material coming in. One of the guys remembers seeing it in the poast so maybe it will come up again
    Byron
