Results 11 to 17 of 17
    Apr 2006
    San Diego
    375
    Thumbs up Thanks for sharing
    Hi Jay,
    Thanks for taking the time to make such a nice post, complete with clear pictures and tutorial.
    Your work looks real good. I make and/or customize a lot of my own tools and machinery, too- a "habit" I picked up from my father.
    What caught my eye, though, was the cool hand-wheel you made for your bead roller. There's nothing like home-made, right?
    Keep up the good work and good luck with school.
    Happy New Year to everyone.
    -Chris
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    Jan 2008
    Anderson, Ca
    31
    Quote Originally Posted by chris***@sbcglo View Post
    Hi Jay,
    -Chris
    Thanks Chris,
    My grandfather gave me the bug to build my own stuff. I tell my wife that part of me is really glad I am not rich, because if I were then I wouldn't have the fun of building all the tools that I can't afford!
    I built the that bead roller out of the Harbor Freight one. I didn't have a tubing bender, but I had a lot of chain!
    Jay
    Sep 2006
    Newcastle, Oklahoma
    70
    Quote Originally Posted by strube1369 View Post
    Really nice project and thanks alot for taking the time to make this into a tutorial. Alot of us really appreciate it! Happy New Year and good luck in school and on the job front.
    As said, thanks, you do great work and great write up. One question how did you finish the edge on the top die?, to a sharp edge?, if so how to make it uniform?
    Jan 2008
    Anderson, Ca
    31
    Quote Originally Posted by smooth72 View Post
    I did not make it into a sharp point. I ground a 45 degree angle on each side of the 3/8 inch plate with a 1/8 inch land in the middle. I used a grinding disc to rough it, a flap disc to smooth it out, and then a flat file to finish it off. The hardest part about doing it this way is to be carefully of rounding the ends. I keep the 7" grinder tight and close to my chest and use my whole body to move the grinder the length of the plate. I also lift up before the end of the plate because no matter what the pressure that is on the grinder will invariablly round the end. I then finish the last bit with a flat file. Just takes time. Hope that helps!
    Jay
    Sep 2006
    Newcastle, Oklahoma
    70
    Thanks, that does help.
    Dec 2010
    Alberta, Canada
    42
    Nice work Jay, clean build, well thought out. The work is a pleasure to look at.
    Gord
    Oct 2008
    Oregon
    193
    I built a welding cart that is steerable, from looking at others carts here.
    I will now change that to swivel pneumatic casters and use the straight chunk of the steerable axle assembly that I got from a riding mower, to use for my brake.
    It looks natural to take it, grind an edge and straighten the pivots, to use for this purpose.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
