Results 1 to 3 of 3
    Jan 2010
    5
    Default Dynasty 200DX stick on Honda EU2000i genny
    I have some light duty, outdoor, remote welding to do and the only available power source is a Honda EU2000i generator. I'm told I can expect about 12A continuous output from this generator at 115V.
    Anyone have any experience with the Dynasty 200DX on low current 115V stick applications? I'm thinking 3/32" 6013 rods...? Unfortunately I don't have access to the generator to do some testing in the shop. My gut tells me I don't have enough generator.
    Thanks.
    Nov 2007
    184
    Can't offer anything about the welder but we've sold Honda for about 30 years.
    The little generator will give you 16.6 amps at 120 volts for about 30 minutes
    before the overload trips. I'd suspect the "inrush" current when you strike
    the arc will be above this, if you can set a parameter on the welder to keep
    it below about 20 amps the generator overload may not trip. Be sure to have
    the eco-throttle switched off to let the generator to at least have a chance.
    Dave
    Near Dallas, TX
    215
    Quote Originally Posted by FM117 View Post
    Dave
    This is a cut-and-paste from an old thread from 2008. andySpike is probably a spammer bot. I think you even responded to the old post
    http://www.millerwelds.com/resources...hlight=EU2000i
    Dynasty200DX w/coolmate1
    MM210
    MM Vintage
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Evolution Rage3
    Jancy USA101
    9" South Bend
    AEAD-200LE
