Results 1 to 9 of 9
Thread: Welding Table
    Apr 2006
    Isleton, California
    4
    Default Welding Table
    I need help designing a flat welding table. I am a fence contractor who is tired of welding on the floor. I need to be able to handle all sizes of chain link and ornamental gates and panels. It must be easy to square up corners too. Any suggestions??
    Thank you
    Mar 2006
    22
    I would buy a sheet of 4x8' 1/4" steel and put 4 legs under it with cross bracing then just weld a couple of jigs on the top for your corners.
    Oct 2005
    Bulverde, Tx
    1,244
    That is what I did. I plan on building another when I finish my shop for the larger stuff. Make them the same and they can be put together for one big honkin' table.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Apr 2006
    Isleton, California
    4
    I weld large gates. 12' High X 20' or more. This is my problem. I also have to be able to reach the reinforcements in the middle of the gates.
    Fast Freddie
    Oct 2005
    Bulverde, Tx
    1,244
    Two tables with jack stands in the middle? When I had some stuff to do out of reach, I just hopped up on the table and took care of it. That would get old if I had to do a lot of it, though.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    Salem ,Ohio
    3,927
    All my tables are the same height so i can move them around to do big stuff and still have the center open...Bob
    Mar 2006
    7
    Here is the perfect solution. I call it the superman!
    Apr 2006
    Isleton, California
    4
    I think this is the best idea yet.
    Fast Freddie
    Mar 2006
    Queens NY
    1,547
    why not make several tables that can be configured to fit a project along with a small rolling stair to get to the middle of a really big job?
