I need help designing a flat welding table. I am a fence contractor who is tired of welding on the floor. I need to be able to handle all sizes of chain link and ornamental gates and panels. It must be easy to square up corners too. Any suggestions??
Thank you
Thread: Welding Table
04-26-2006, 10:15 PM #1
Welding Table
04-26-2006, 10:50 PM #2
- Mar 2006
- 22
I would buy a sheet of 4x8' 1/4" steel and put 4 legs under it with cross bracing then just weld a couple of jigs on the top for your corners.
04-26-2006, 11:15 PM #3
That is what I did. I plan on building another when I finish my shop for the larger stuff. Make them the same and they can be put together for one big honkin' table.
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
04-26-2006, 11:44 PM #4
Welding Table
I weld large gates. 12' High X 20' or more. This is my problem. I also have to be able to reach the reinforcements in the middle of the gates.
Fast Freddie
04-27-2006, 07:35 PM #5
Two tables with jack stands in the middle? When I had some stuff to do out of reach, I just hopped up on the table and took care of it. That would get old if I had to do a lot of it, though.
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
04-28-2006, 02:03 AM #6
All my tables are the same height so i can move them around to do big stuff and still have the center open...Bob
05-01-2006, 02:42 PM #7
- Mar 2006
- 7
Here is the perfect solution. I call it the superman!
05-02-2006, 08:30 AM #8
I think this is the best idea yet.
Fast Freddie
05-05-2006, 11:59 PM #9
- Mar 2006
- Queens NY
- 1,547
why not make several tables that can be configured to fit a project along with a small rolling stair to get to the middle of a really big job?
