Thread: pulstar 450???
    Default pulstar 450???
    what do you think of the welder? Can you stick weld with it? If how,how do you set the settings.
    May 2010
    Central CA
    785
    Default CV machine
    The Pulstar 450 is a CV only welder and 3-phase. Constant Voltage
    For stick you need CC. Constant Current
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    8,325
    It was seemingly a poor to good machine for its time, but it pulses too slow for virtually any application, and yes it's a 3 phase, CV only machine.
    thanks for the info. you been alot of help.
    Mar 2010
    Ceres, California
    358
    weighs 590 pounds. It is basically two 3 phase cv welders in one case.
    To be able to pulse weld you must have the matching feeder.
    other wise you only mig weld no pulse
    Glenn 300 amp stick
    Millermatic 35
    L-tec plasma
