Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Dynasty 200 DX
    Jan 2008
    Slovenia, Ljubljana
    44
    Default Dynasty 200 DX
    Could somebody please tell me what is the max thicknes for aluminium, stainless steel and steel that you can weld it with Dynasty 200 DX ?
    132
    The short answer is:
    It depends.
    ...on joint style, whether you preheat, etc.
    You have 200amps to play with. Maybe an effective 250 if you change the frequency (according to Miller). You can check out one of Miller's weld calculators to get you in the ballpark.
    I've never had a need to max mine out, but I do 1/8 aluminum, 1/4 steel and 16 ga. stainless all the time.
    -James
    Jan 2008
    Slovenia, Ljubljana
    44
    Thank you for the answer. Have a great time and a happy new year !! oh i have just three more questions. Do you own Dynasty 200 DX ? if you, is it good because i'm thinking of buying one ? is it making any troubles ?
    Apr 2007
    Manchester, NH
    28
    I have a Dynasty 200DX. It is a great welder, I have not had any problems with it. I have welded 3/16" aluminum with it.
    What do you plan to use it for?
    Tom
    Midland, Mi.
    313
    As said above, it depends. I have welded from .010 up to 3/4" aluminum with mine.
    Jan 2008
    Slovenia, Ljubljana
    44
    Thanks for the answer. i would like to weld some chairs made of stainless steel, modified bikes like adding some sheet metal, i would also like to build a gokart one time, and also welding aluminium.
    i have a mig welder, but for the precise work you need tig welder
    if you are interested, i can show you some pics of steel shack and steel projecting roof which i have made it with mig welder:
    Jan 2008
    Slovenia, Ljubljana
    44
    Here are some more:
    Apr 2007
    Manchester, NH
    28
    Thank you for posting your pictures. Your work looks very nice! What are you using for a MIG welder?
    I think that you will be very happy with a Dynasty 200DX. I know that I am very happy with mine.
    Alaska
    732
    Unlimited!
    If you know how to weld.
    Sorry to be an A hole but the truth is tha machine will put out X amount of amps period, what you do with them is all up to you.
    With the correct weld joint and some preheat 200 amps and 20% duty cycle will let you weld well at thickness exceeding 1" Aluminum stainless and steel
    Please rephrase your Question so it can be answered.
    TJ
    Jan 2008
    Slovenia, Ljubljana
    44
    Thanks again for the answers!
    i'm using my mig welder for welding shelfs, tables, shacks, and projecting roofs.i'm using Iskravar 210 L mig welder which is fabricated in my country, Slovenia and i have a Miller's helmet Inferno with which i'm very satisfied
    Villemur, thanks for the praise. What are you using a Dynasty 200 DX for ?
