    Jul 2009
    Australia
    1,031
    Default More Dirt Bike Chassis Repairs
    This was a chain roller guide.
    When the nylon roller wears down no one seems to replace them and the end result is the roller guide gets ground down.
    A few hours later in the workshop a whole new bracket and roller guide ready to weld on the frame.
    Ji
    Grip it and Rip it
    Apr 2010
    Jackson, MS
    79
    I bet this repair is going to cost more than just routine maintenance. Plus the dude has to get the nylon roller too.
    MillerMatic 252
    Spoolmate 200
    Diversion 165
    Spectrum 625 X-Treme
    Dayton 6" Miter Band Saw
    Delta Drill Press
    Bosch 10" Table Saw
    Jet 5 Ton Chain Hoist
    Radnor O/A
    Jul 2009
    Australia
    1,031
    Yep
    The nylon roller only costs $5.00.
    I will never get it.
    I have the OEM roller but may lathe a custom one just to finish the repair with a little extra bling.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    So I could line the new bracket up in the right spot I made a very basic jig.
    This should also hold the bracket while I weld it onto the frame.
    Ji
    Grip it and Rip it
