Results 1 to 9 of 9
    Nov 2006
    Benton, Pa
    68
    Default Cast iron/cast steel
    Is there an easy way to determine if I have a piece of cast steel or if it is cast iron?
    2
    Aug 2007
    New Orleans, LA
    161
    If it will cut with a torch it is cast steel, cast iron will only melt
    Lincoln: Eagle 10,000, Weld-Pak HD, Weld-Pak 155, AC-225, LN-25 wirefeeder
    Miller: Syncrowave 250DX Tigrunner
    Westinghouse: 400+ amp AC
    ThermalArc Handy wirefeeder
    1 Harris, 3 Victor O/A rigs
    Arcair gouger
    Too many other power toys to list.
    Do it right, do it once. And in all things ya get what ya pay for.
    Jul 2007
    Lancaster, Pa
    431
    Usually cast iron has a rough finish to it such as a cast iron frying pan or weights in a gym, engine blocks, looking close enough, you can see or feel the pores from the sand casting.
    Cast steel has a smooth finish to it like some cookware, motor housings, gears, sprockets, etc.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Jan 2007
    Noth Dakota
    505
    Cool
    Spark test.
    Oct 2007
    gate city virgina
    213
    what is a spark test?
    Mar 2007
    ****inson ND
    557
    Talking
    Cast Iron will make a thud type sound if you hit it with a hammer wheras cast steel will haver more of a ring sound to it.
    Jan 2007
    Midland, Mi.
    313
    Mig weld a piece of scrap steel to it.
    If it holds - cast steel
    If it falls off - cast iron
    LOL
    Oct 2007
    Cave Creek Az
    962
    Toe test! drop it on your toe, cast steel makes you say OOUUChh !,cast iron makes you say@#%%#^%#
    Seriously though, spark test. Dull orange sparks off a grinding wheel are iron, steel is yellow.
