Results 1 to 10 of 11
Hybrid View
    Nov 2010
    north carolina
    8
    Default Building a gas grll
    New here thought id post some photos of the gas grill i'm building..
    Nov 2010
    north carolina
    8
    welded sides in , added shelves. thermometer,instead of adding the traditional pipes,headers etc. opted to add a small breather across the back for the smoke and aroma exit..
    Nov 2010
    north carolina
    8
    tacked together and welded. and the top is finished.. i dont really like the thermometer placement so on the next one i'll make a change.. maybe raise to creat a bump between the top and the first bend..
    sweet looking grill when do get get pics of it grillin steaks
    never thought of a gas grill only ever build a trailer bbq smoker
    Leblond Makino mills
    HAAS CNC SL-40 lathe
    American Pacemaker lathe
    wells index mill
    hydrotel rebuilt
    syncrowave 250
    diversion 165
    Miller Elite Vintage USA
    Nov 2010
    north carolina
    8
    thanks..
    i will be working on the bottom this week, adding the vents for air. also building the burner and another stand, or rebuild the one that its sitting on
    the goal is to have it finished by the weekend, and weather permitting paint.
    The first burn will be a rack of ribs !!
    the next project just happens to be a pull behind gas pig cooker. im still gather material together for it, and still choosing again not to use barrels or stacks. nothing against them though.
    Nov 2010
    north carolina
    8
    finished the bottom today. Added the air inlets to help it breath. Also cut & bent the pipe for the burner. cleaning it up in the morn, weld it and drill the holes. alittle bit of cleanup and fire this puppy up tomorrow hopefully.
